Back up to LAN
I am using a mint 17.3 64bit system.
I want to back up my files to the WD My Book Live storage on the LAN.
However mint back up has no option to make back ups on the LAN. In the past I backed up to the desktop and then copied on the the LAN storage.
There must be a way to make back ups to the LAN. Any help appreciated.
Are you mounting the NAS at boot via fstab ?
Does the NAS require a password to login ?
Do you know the NAS IP address ?
Ans- No
Ans- No
Ans- Yes fixed IP Address
Okay can you mount the NAS share via the file manager (so you can see is contents)
then post the output from:
mount
userone@Office2 ~ $ mount
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/pstore type pstore (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=userone)
userone@Office2 ~ $
Okay, that didn’t tell me what I wanted to know :-\
What’s the IP of the NAS ?
http://192.168.0.15
If you run:
mkdir /mnt/nas
sudo chown tramlink:tramlink /mnt/nas
sudo chmod 777 /mnt/nas
sudo mount -t cifs -o iocharset=utf8,dir_mode=0777,file_mode=0777 //192.168.0.15/share /mnt/nas
are the shares now available if you go to /mnt/nas ?
obviously you may need to change “tramlink” in the above command if that’s not your username.
and you may need to change //192.168.0.15/share if that’s not the actual shared directory on the NAS
Hi, changed user name
Entered share name on the nas.
go to /mnt/nas
I can see the folders within the named share (“public”)
First let’s backup your fstab … run:
sudo cp -v /etc/fstab /etc/fstab.bak
Okay now open fstab for editing:
sudo gedit /etc/fstab
and add a new line at the bottom that (following my above example) reads:
//192.168.0.15/share  /mnt/nas  cifs  iocharset=utf8,dir_mode=0777,file_mode=0777  0  0
(adjust that as necessary)
SAVE that file and exit gedit
then run:
sudo mount -a
if you get no errors … reboot, and see if after the reboot you can still access the share at /mnt/nas
if that worked and it’s now automounting the share at boot … just do your backing up to /mnt/nas
That seems to be working was able to back up files the the nas.
Hope they add LAN back up as standard with the next LTS update.
