bash scripts not working
I have just installed the latest Linux Mint 64 bit and have just found that bash scripting no longer works, so tried a simple script;
uname -a
Linux mint 2.6.35-22-generic #35-Ubuntu SMP Sat Oct 16 20:45:36 UTC 2010 x86_64 GNU/Linux
e.g.
vi hello
#!/bin/bash
echo “Hello World”
chmod +x hello
./hello
bash: ./hello: Permission denied
It even fails as root
Interestingly is that I have just tried it on another system using the same build and it works fine.
Any suggestions?
Where is the hello script located ?
if it’s outside your home directory you’ll have to chmod +x it with root permission
sudo chmod +x /path/to/sript/hello
and run it with root permission
cd /path/to/script
sudo ./hello
if hello IS in your home directory… you might want to check who owns the script
ls -l hello
will give you an output like:
-rwxr–r-- 1 mark mark 31 2010-11-04 13:26 hello
where mark mark is owner group
Thanks, guys.
I am using the script in my home directory and it belongs to me.
I believe that I have located the problem. it is the way that I am mounting my home directory disk.
i.e. (as root)
./hello fails when it exists in my home directory folder but if I move the file down to the root folder it then it works.
typing mount reveals;
/dev/sdc1 on /home type ext3 (rw,noexec,nosuid,nodev,commit=0)
so fstab entry for the disk is wrong, it appears that noexec and nosuid are added by default.
So what is the line for sdc1 (/home) in your /etc/fstab ?
just for comparison, here’s mine:
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /home ext3 defaults 0 2
obviously the UUID has been replaced with x’s, as I couldn’t be bothered to write it :wink:
Thanks Mark.
Problem solved.
My previous settings (the problem one) was;
/dev/sdc1 /home ext3 rw,user 0 0
which I have now changed to
/dev/sdc1 /home ext3 rw 0 0
Everything works now and the command mount reveals;
/dev/sdc1 on /home type ext3 (rw,commit=0)
No problem (not that I did anything), glad you solved your problem though… :slight_smile:
