Best Antivirus & Firwall
The main desktop computer is connected directly through cable, it is not wireless enabled… When we got laptops and notebooks which require a wireless router we had to get Virgin Media to supply a router so that that they could be used.
Connected to what? ???
Have you got 2 separate connections to the Virgin cable as it enters into your premises?
I think what Mark & SeZo are trying to establish is, Is the cable from your PC connected to the router or the cable modem and is the cable ethernet or USB ?
Yes I get what you mean now- I have a router from my internet provider and it’s wi fi. My phone line is also in it.
Further to my question (above) I cannot get a firewall to work in PP4.
EDIT I will start a new topic.
I like to use APF Advanced Policy Firewall – R-fx Networks on my deployments
