Bleachbit {Solved}
Previously used bleachbit on Ubuntu ect.for cleaning up.
Is this suitable for Peppermint…?.
Jocklad
As far as I know yes.
I’ve used it with Peppermint 3 and 4 no problems. I did have issues with Ubuntu though, which is strange as Peppermint is based on Ubuntu.
Have run bleachbit …system working fine.
Thanks Guys.
Jocklad :slight_smile:
For the small part I played … you’re welcome :slight_smile:
If you consider it so, please don’t forget to mark the topic (SOLVED) :wink:
(by editing the subject line of the FIRST posting)
[EDIT[
I know it wasn’t really a problem, more a question, but it still helps people with the same question find an answer they can trust … it also help people on here know the topic no longer requires attention.
I thank you kind sir :slight_smile:
