Bluetooth not working mint 17 mate 64bit (solved)
I plugged my Trust bluetooth receiver into a USB port and nothing happened I checked in the Package Manager and it says Bluetooth is installed.
The adaptor power light is on.
I have used bluetooth in the past but not for about 6 months. what could be the problem.
Any help appreciated.
With the adapter plugged in, what is the output from lsusb?
userone@Office2 ~ $ lsusb
Bus 003 Device 008: ID 0a5c:2101 Broadcom Corp. BCM2045 Bluetooth
Bus 003 Device 003: ID 1bcf:0002 Sunplus Innovation Technology Inc.
Bus 003 Device 002: ID 046a:010d Cherry GmbH
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
userone@Office2 ~ $
any output from:
rfkill list
userone@Office2 ~ $ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
userone@Office2 ~ $
The power light comes on but nothing else happens I remember an icon used to show bluetooth was active and my phone can not see the computer for pairing.
What’s your output from:
uname -a
also
apt-cache policy bluez
userone@Office2 ~ $ uname -a
Linux Office2 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
userone@Office2 ~ $
userone@Office2 ~ $ apt-cache policy bluez
bluez:
Installed: 4.101-0ubuntu13.1
Candidate: 4.101-0ubuntu13.1
Version table:
*** 4.101-0ubuntu13.1 0
500 http://archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
100 /var/lib/dpkg/status
4.101-0ubuntu13 0
500 http://archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
N: Ignoring file ‘getdeb.list.bck’ in directory ‘/etc/apt/sources.list.d/’ as it has an invalid filename extension
userone@Office2 ~ $
Make sure bluez and blueman are installed:
sudo apt-get install bluez blueman
then in blueman make sure the PC is set to be discoverable.
That seems to have sorted out the problem.
Thanks for the help.
No problem :slight_smile:
