Brother MFC-J5910DW wireless printer problems
I am back with this problem with this printer.
I can not get the wireless connection to work. I had a topic here in September but I was able to use the Windoze computer to print out my sketches. I have now lost the Windoze computer and would like to establish a wireless connection with my Novatech computer running Pep 7.
Can you help ? where do I start ?
take care
Don W
Have a look here
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=mfcj5910dw_all&faqid=faq00002037_013]
Once you get it connected to your wlan it should just be a question of installing the printer in the normal manner
Good luck
Thanks Graeme,
I will go through this in the morning after my visit to the doc.
take care
Don W
PS I have this printer connected wirelessly with the Windows computer and it works ok. These instructions look much the same as when I connected the Windows computer. Hope fully it should all go well.
If you have this printer connected with your Windows PC you shouldn’t need to do it again it should already be registered to your network
all you should need to do now is install the printer
Menu>System Tools>Printers
When the printer dialogue box opens click + Add on next screen click Network Printers and your printer should be listed select your printer then just follow the instructions
Good luck
Thanks Graeme,
Carried out your latest suggestion and the printer has printed a test page.
Went upstairs and printed out a page from Writer and it worked well. Looks as if it is a success.
Thanks again
take care
Don W
You’re welcome don
Glad you got it working :slight_smile:
Nice one Graeme :slight_smile:
