Can I load Num Lock during boot (Solved)
Hi Guys
This might seem quite trivial but it annoys the hell outta me
Is it possible to load the number pad (at the right of the keyboard) during boot, preferably before the log in screen, my log in password has numbers in it and I continually use the number pad forgetting to press Num Lock which places the cursor at the beginning of the unfinished password,
I know this must seem quite trivial but it is very annoying
any help would be much appreciated
Many thanks
This is a hardware function, not software … see if there is a setting in the system BIOS to enable numlock at system startup
Hold on … maybe it can be done in software :slight_smile:
https://help.ubuntu.com/community/NumLock
Which Linux distribution are we talking about ?
Thank you Mark I’ll check it out and let you know :slight_smile:
Many thanks
NO DON’T
Just answer my question … which Linux distribution … Ubuntu/Mint/Peppermint ?
If Peppermint 3 … run:
sudo apt-get install numlockx
sudo gedit /etc/lightdm/lightdm.conf
When lightdm.conf opens for editing … add a NEW line at the bottom that reads:-
greeter-setup-script=/usr/bin/numlockx on
SAVE the file … and reboot to test the numlock is ON at the login screen.
Mark, you’re some man to be one man
Working perfect thank you again
All that’s left to do is mark it solved
Many thanks
Who said I’m only one person … there are 3 of us … one of us is King Leopold (he’s hard to understand … mumbles Belgian through his beard), another is Albert Einstein (even harder to understand … you know why), and then there’s Mark (I’m not quite sure about him yet).
Hmm, as I talked about all 3 of them in the third person … maybe there’s 4 of us :o
From what I know about King Leopold he was not a nice guy and although old Albert was one smart cookie he (like King Leopold) knew f@@k all about Linux, So that only leaves one man :slight_smile:
We’re all in agreement … I think … it’s hard to tell, what with the mumbling and equations.
sudo echo "we're all in agreement"
Now we are :wink:
