Can't get my Computer to see my Wireless Adapter
dmesg | tail -n 20
[ 1519.055141] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1519.063062] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1519.063569] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1540.044144] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 2891.659745] usbcore: deregistering interface driver ndiswrapper
[ 2891.684537] ndiswrapper: device wlan0 removed
[ 2899.645453] usb 1-5: USB disconnect, device number 8
[ 2916.440044] usb 1-5: new high-speed USB device number 9 using ehci-pci
[ 2916.572421] usb 1-5: New USB device found, idVendor=148f, idProduct=2870
[ 2916.572430] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2916.688048] usb 1-5: reset high-speed USB device number 9 using ehci-pci
[ 2916.836400] phy3 → rt2800_init_eeprom: Error - Invalid RF chipset 0xffff detected.
[ 2916.836411] phy3 → rt2x00lib_probe_dev: Error - Failed to allocate device.
[ 2934.205875] usb 1-5: USB disconnect, device number 9
[ 2946.984049] usb 1-5: new high-speed USB device number 10 using ehci-pci
[ 2947.116385] usb 1-5: New USB device found, idVendor=148f, idProduct=2870
[ 2947.116395] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2947.232050] usb 1-5: reset high-speed USB device number 10 using ehci-pci
[ 2947.459488] phy4 → rt2800_init_eeprom: Error - Invalid RF chipset 0xffff detected.
[ 2947.459500] phy4 → rt2x00lib_probe_dev: Error - Failed to allocate device.
I’m beginning to think there may be a problem with the adapter because of these lines:
[ 2947.459488] phy4 -> rt2800_init_eeprom: Error - Invalid RF chipset 0xffff detected. [ 2947.459500] phy4 -> rt2x00lib_prob e_dev: Error - Failed to allocate device.
Can you now blacklist these 3 modules
blacklist ndiswrapper
blacklist rt2800usb
blacklist rt2x00usb
UN blacklist rt2870sta
SAVE the file
REBOOT
Unplug/replug the device and post the output from:
dmesg | tail -n 25
so we get a picture of what’s going on when that driver is used.
dmesg | tail -n 25
[ 112.066299] ERROR!!! E2PROM: WRONG VERSION 0xff, should be 1
[ 112.069426] phy mode> Error! The chip does not support 5G band 1!
[ 112.069688] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 112.080800] 3. Phy Mode = 9
[ 112.088800] MCS Set = ff ff 00 00 01
[ 112.099360] <==== rt28xx_init, Status=0
[ 112.101049] 0x1300 = 00064300
[ 112.126417] ERROR!!! RTMPSetTimer failed, Halt in Progress!
[ 112.643283] -->RTUSBVenderReset
[ 112.643404] <–RTUSBVenderReset
[ 112.939569] Key1Str is Invalid key length(0) or Type(0)
[ 112.939592] Key2Str is Invalid key length(0) or Type(0)
[ 112.939609] Key3Str is Invalid key length(0) or Type(0)
[ 112.939626] Key4Str is Invalid key length(0) or Type(0)
[ 112.939907] 1. Phy Mode = 5
[ 112.939909] 2. Phy Mode = 5
[ 112.957898] ERROR!!! E2PROM: WRONG VERSION 0xff, should be 1
[ 112.961775] phy mode> Error! The chip does not support 5G band 1!
[ 112.962047] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 112.974651] 3. Phy Mode = 9
[ 112.983652] MCS Set = ff ff 00 00 01
[ 112.995084] <==== rt28xx_init, Status=0
[ 112.997395] 0x1300 = 00064300
[ 113.013279] /home/poetic/rt2800/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_asic.c:3425 assert KeyIdx < 4failed
[ 113.014527] /home/poetic/rt2800/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_asic.c:3425 assert KeyIdx < 4failed
Is your router using the 5ghz band rather than 2.4ghz ?
It’s a dual band router which can work with 2.4 or 5ghz adapters. I think the issue here is that I don’t have a valid chipset for the driver that is being used. In addition, I can’t get a vaiid MAC address registered in order for this adapter to be recognized by my router. I really appreciate all the efforts you have supplied to try to get this adapter working, but I think I’m SOL.
I will work with the vendor that I bought the adapter from and see, if I can return it for another one. if I get the same problem, then I will chalk it up to this adapter just is not going to work with my hardware.
Just a side note, I also tried to get this adapter working with Windows 7 using the supplied Window drivers and it also has the MAC Address problem. So on two different computers and two different OS’s, this adapter does not work.
It seems to be trying to connect at 5ghz … and I’m not sure this driver (or adapter) works at 5ghz
Is it possible to turn off 5ghz on your router, just as a test. ?
If that doesn’t work, I’d guess it’s a hardware issue as you suggest.
Let me check the manual. I’ll report back one way or the other.
The closest I could find to turning off 5ghz was to hide the 5ghz SSID. After unplugging and plugging in the adapter I get the same error message that I posted with the last dmesg | tail -n 25.
Well whether it’s hardware or just that the adapter doesn’t like your router, I guess you ARE SOL as you put it :slight_smile: … try to swap it for another brand if you can.
I was just reading this:
seems it DOES work with 5ghz … but doesn’t like high channels … is it possible to do what the dmesg output asked and select a lower channel in the router ?
[ 112.066299] ERROR!!! E2PROM: WRONG VERSION 0xff, should be 1 [ 112.069426] phy mode> Error! The chip does not support 5G band 1! [ 112.069688] RTMPSetPhyMode: channel is out of range, use first channel=1
I’m looking through the settings and I don’t see a channel selector. The router I have is an Asus RT-AC66R. I’m digging.
On the Wireless Tab there is a Control Channel option. It is currently set to Auto. The options in the Drop down are many:
36, 40, 44, 48, 149, 153, 157, 161, 165.
try 36
then replug the adapter
and check what:
dmesg | tail -n 25
says now.
I’ll need to redo the blacklist.conf file so give me a couple of minutes.
no problem :slight_smile:
It might also be a good idea to restart the router after changing channels … normally this isn’t necessay but the guy with the “Airplay” router said he needed to … so can’t hurt :slight_smile:
Here’s the output after making the changes to the router and the blacklist.conf file.
dmesg | tail -n 25
[ 4661.273686] ERROR!!! E2PROM: WRONG VERSION 0xff, should be 1
[ 4661.276688] phy mode> Error! The chip does not support 5G band 1!
[ 4661.276956] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 4661.288811] 3. Phy Mode = 9
[ 4661.296812] MCS Set = ff ff 00 00 01
[ 4661.307363] <==== rt28xx_init, Status=0
[ 4661.308935] 0x1300 = 00064300
[ 4661.334179] ERROR!!! RTMPSetTimer failed, Halt in Progress!
[ 4661.854042] -->RTUSBVenderReset
[ 4661.854164] <–RTUSBVenderReset
[ 4662.131193] Key1Str is Invalid key length(0) or Type(0)
[ 4662.131215] Key2Str is Invalid key length(0) or Type(0)
[ 4662.131231] Key3Str is Invalid key length(0) or Type(0)
[ 4662.131248] Key4Str is Invalid key length(0) or Type(0)
[ 4662.131528] 1. Phy Mode = 5
[ 4662.131530] 2. Phy Mode = 5
[ 4662.147408] ERROR!!! E2PROM: WRONG VERSION 0xff, should be 1
[ 4662.150532] phy mode> Error! The chip does not support 5G band 1!
[ 4662.150806] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 4662.162156] 3. Phy Mode = 9
[ 4662.170282] MCS Set = ff ff 00 00 01
[ 4662.180837] <==== rt28xx_init, Status=0
[ 4662.182281] 0x1300 = 00064300
[ 4662.194292] /home/poetic/rt2800/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_asic.c:3425 assert KeyIdx < 4failed
[ 4662.195534] /home/poetic/rt2800/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_asic.c:3425 assert KeyIdx < 4failed
I get the feeling this is a 5ghx problem, and the firmware getting confused … possibly that there’s a certain component on that particular adapter that just plain doesn’t like your router.
Would be interesting to see if you get a proper MAC addreess with your router turned off, then repluging the adapter
I’ll give that a shot and report back.
I unplugged the router and still get this bogus MAC Address:
ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:e0:4c:dd:4a:f5
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:216 errors:0 dropped:0 overruns:0 frame:0
TX packets:216 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:22983 (22.9 KB) TX bytes:22983 (22.9 KB)
ra0 Link encap:Ethernet HWaddr 90:ff:ff:ff:ff:ff
inet6 addr: fe80::92ff:ffff:feff:ffff/64 Scope:Link
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:152 (152.0 B)
