chmod question
What three-digit number would you use with chmod to set the following permissions to a file -rw-------
The simple answer is 600
There is a chmod calculator here
https://chmod-calculator.com/
Your example signifies, read and write, but no execute permissions for the file owner ONLY … there are no permissions for either group or everyone else.
Thanks, so rw is read write and then is it the lack of anything else or the dashes that signify the person can’t change permissions?
think of your example in 4 sections
The first - will be one of - (= file), d (= directory), or l (= symlink)
the next three are the permissions of the file owner
the next three are the permissions of the group the file belongs to
the next three are the permissions of everyone else
options are r (read), w (write), x (execute)
r=4
w=2
x=1
so in your example:-
rw- = 4+2+0 = 6
= 0+0+0 = 0
= 0+0+0 = 0
so is represented as 600
So if you look at the text under my avatar (to the left), you’ll see it ‘actually’ reads “666 … The Number Of The Beast” :wink:
ahh so because there was just rw and the -, and not an x instead of the dash it means I can’t execute permissions.
Can I also ask how do I find out which of my files has a stickybit set out of these:
-rw-r–r-- 8 1
-rwxrwxrwx 7 2
-rw-r–r-- 6 3
-rwxr-xr-t 5 4
-rw-r–r-- 4 5
-rwSr–r-- 3 6
lrwxrwxrwx 1 7
Thats not how they actually appear; I put a number instead of the linux/date/file name. I know the answers 4 but idk how to get there.
it means the file will allow ONLY it’s owner to read it, to write to it, but not to execute it (if it’s actually an executable).
so why was number 4 right then?
extended attributes are explained quite well here
Thanks alot, I managed to do the last one too. Lonk helped alot!
