Choosing a sound device
How exactly do it with linux lubuntu 15.10?
Does lubuntu use pulseaudio ?
what’s the output from:
dpkg -l | grep pulseaudio
And just as a matter of interest, can I ask why you chose Lubuntu over Peppermint ?
Becausemy computer is very weak
& I do not know how to use it.& how to install it.
Peppermint (not Mint) is based on Lubuntu, but comes with things like pulseaudio out of the box … so is generally easier to configure
Anyway, how about the output I asked for ?
rami@rami-System-Product-Name:~$ dpkg -l | grep pulseaudio
so what to do?
Your options are to configure your sound device(s) via:
alsamixer
or to install pulseaudio:
sudo apt-get install pulseaudio pulseaudio-utils pavucontrol
then configure it via:-
menu > Sound & Video > PulseAudio Volume Control
