Does not seem to offer the last step.....Addit ional Drivers !!
So how did you get to “Additional Drivers” as shown by your screenshot ?
I used this code from Mark Greaves
software-properties-gtk
Can you try the fglrx-updates driver.
I’d be amazed if the proprietary drivers from AMD were worse than the open source ones :o
After installing fglrx and rebooting … is there a Catalyst Control Panel in the menu’s somewhere ?
and can you post the output from:
sudo lshw -C display
again, so we can be sure fglrx loaded
can you also post the output from:
ls -a /etc/X11
Can you clarify what version of Zorin you’re running and if your system is 32 or 64 bit ?
Latest Zorin 7.1 64 bit.
Just been told I am going shopping !!! Sorry for delay. Will be 1-2 hours. Be back then.
Thanks
Okey dokey
No catalyst panel as I can see.
screenshots…
next one…
Now have “AMD unsupported hardware” in bottom right corner
Have found Catalyst Control Center.
Can you run:
sudo updatedb
then post the output from
locate xorg.conf
as catalyst doesn’t apper to have created one.
Hi ,
Spent all morning playing same (freshly recorded) clip on Zorin. Whether I select VLC Sm player, or Videos, the play back is not smooth. Certainly not unwatchable, but not smooth. On playing same clip in Win 7 laptop (i3 and 6gb) using VLC, Media player and Media player classic the results are smooth as silk.
Now, I really want to use a Linux base as, short of the video editing, I have found all I want to do from a second computer.
This is new build with AMD A10k proc with inbuilt HD radeon grahics and 8gb fast 2100 ram so I’m not thinking it’s the processing power of machine !
Prior to install of Zorin, Camtasia ran fine on the machine with Win 8 trial and all playback using above progs. was smooth.
Can I install another Linux to run alongside Zorin like Windows dual boot ?
Thanks for your input.
Seems to me this is JUST a driver issue … you STILL don’t have an xorg.conf file in the right location.
is there an option in the catalyst control center to create one … or “save settings” or similar ?
if not, we’ll try manually creating one.
I certainly cant see an option. Please find screenshot
OK, what happens if you run:
sudo aticonfig --initial -f
then what’s the output from
ls -al /etc/X11/xorg.conf
I’m going to post a link here that it may be a good idea to reed before you reboot … specially the bit on what to do if you get a black screen after rebooting
No support adapters detected
OK, let’s try this a different way
do you think you could do that, or do you require help ?
if you need assistance, please post the output from:
uname -a
so we can see if you’re running 32 or 64bit
