Chrome for Mint 13 (SOLVED)
I’m having problems with Firefox constantly freezing/crashing so have decided to try Google Chrome instead.
On the Chromium page, chromium - An open-source project to help move the web forward. - Monorail, it gives a list of distros but doesn’t mention Mint.
Can I use any of the distros listed?
Thanks in advance.
Chromium (open source version of Chrome) will be in your default repository … to install just open a terminal and run:
sudo apt-get install chromium-browser
or if you want Chrome … go to here:
and download/install the .deb version that suits your OS architecture (32bit or 64bit)
Many thanks Mark as always. :slight_smile:
You’re welcome (as always) :slight_smile:
I take it it’s working now ?
Ignore that … I hadn’t noticed you’d marked the topic (SOLVED) :wink:
Yes it’s working fine, thanks.
Happy to hear it :slight_smile:
See my edit above.
