Cisco Packet Tracer
Hi, I am trying to install Cisco Packet Tracer 6.0.1 on Fedora 19 and having no joy whatsoever.
The cisco website that I logged into (netacad) to get the software let me choose between a copy for “linux” and a copy for ubuntu and with the little knowledge I have of linux I decided that the ubuntu one was no good as of rpm vs deb.
Now there is nothing executable (right phrase? only just switched from windows) in the folder that contains many files and subfolders including a file called ‘install’ but I just can’t work out what to do.
I then gave up and went on this —> Install Cisco Packet Tracer under Linux | ShutterTux - Photography & Life!
which had a file to download and some code examples that should work, which don’t. A chmod command with no responses and and an execute command also no response.
On a ubuntu forum someone posted a .bin file, and this was the closest I got, as I managed to get all the way to the license agreement in the terminal but then it immediately fails with error dpkg command not found. I guess dpkg is a .deb based command?
Please can anyone help, I really need this software for my CCNA course.
I get the feeling from my research that I could get it on a Ubuntu variant quite easily however after trying to install Mint with a catastrophic failure (nothing I did, I don’t think, just a failed install if you beleive me :P) I am put off trying new distro’s for now and as I have fedora running fairly well I want to keep it how it is at the moment.
I can give more information if you want, might even let you ‘see’ what I downloaded from Cisco in the first place.
~Andy
I then gave up and went on this ---> http://shuttertux.wordpress.com/2013/09/25/install-cisco-packet-tracer-under-linux/ which had a file to download and some code examples that should work, which don't. A chmod command with no responses and and an execute command also no response.
Hmm.. The instructions are simple and easy to follow. First of all, where did you download the file to and what was the file name?
Iknow…!
Downloaded PacketTracer533_i386_installer-rpm.bin to /home/aturner/Downloads/
OK try this:
cd ~/Downloads
then (that is lower case L)
ls | grep PacketTracer
Thanks this has got me further!
Now though it needs all these dependancies:
libICE.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libSM.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libX11.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libXext.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libXi.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libXrandr.so.2 is needed by PacketTracer-1:5.3.3-1.i586
libXrender.so.1 is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.0) is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.1) is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.1.2) is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.1.3) is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.2) is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.3) is needed by PacketTracer-1:5.3.3-1.i586
libc.so.6(GLIBC_2.4) is needed by PacketTracer-1:5.3.3-1.i586
libdl.so.2 is needed by PacketTracer-1:5.3.3-1.i586
libdl.so.2(GLIBC_2.0) is needed by PacketTracer-1:5.3.3-1.i586
libdl.so.2(GLIBC_2.1) is needed by PacketTracer-1:5.3.3-1.i586
libfontconfig.so.1 is needed by PacketTracer-1:5.3.3-1.i586
libfreetype.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libgcc_s.so.1 is needed by PacketTracer-1:5.3.3-1.i586
libgcc_s.so.1(GCC_3.0) is needed by PacketTracer-1:5.3.3-1.i586
libgcc_s.so.1(GCC_4.0.0) is needed by PacketTracer-1:5.3.3-1.i586
libgcc_s.so.1(GLIBC_2.0) is needed by PacketTracer-1:5.3.3-1.i586
libglib-2.0.so.0 is needed by PacketTracer-1:5.3.3-1.i586
libgthread-2.0.so.0 is needed by PacketTracer-1:5.3.3-1.i586
libm.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libm.so.6(GLIBC_2.0) is needed by PacketTracer-1:5.3.3-1.i586
libm.so.6(GLIBC_2.1) is needed by PacketTracer-1:5.3.3-1.i586
libm.so.6(GLIBC_2.2) is needed by PacketTracer-1:5.3.3-1.i586
libpng12.so.0 is needed by PacketTracer-1:5.3.3-1.i586
libpng12.so.0(PNG12_0) is needed by PacketTracer-1:5.3.3-1.i586
libpthread.so.0 is needed by PacketTracer-1:5.3.3-1.i586
libpthread.so.0(GLIBC_2.0) is needed by PacketTracer-1:5.3.3-1.i586
libpthread.so.0(GLIBC_2.1) is needed by PacketTracer-1:5.3.3-1.i586
libpthread.so.0(GLIBC_2.2) is needed by PacketTracer-1:5.3.3-1.i586
libpthread.so.0(GLIBC_2.2.3) is needed by PacketTracer-1:5.3.3-1.i586
libpthread.so.0(GLIBC_2.3.2) is needed by PacketTracer-1:5.3.3-1.i586
librt.so.1 is needed by PacketTracer-1:5.3.3-1.i586
librt.so.1(GLIBC_2.2) is needed by PacketTracer-1:5.3.3-1.i586
libstdc++.so.6 is needed by PacketTracer-1:5.3.3-1.i586
libstdc++.so.6(CXXABI_1.3) is needed by PacketTracer-1:5.3.3-1.i586
libstdc++.so.6(CXXABI_1.3.1) is needed by PacketTracer-1:5.3.3-1.i586
libstdc++.so.6(GLIBCXX_3.4) is needed by PacketTracer-1:5.3.3-1.i586
libstdc++.so.6(GLIBCXX_3.4.11) is needed by PacketTracer-1:5.3.3-1.i586
libstdc++.so.6(GLIBCXX_3.4.9) is needed by PacketTracer-1:5.3.3-1.i586
libz.so.1 is needed by PacketTracer-1:5.3.3-1.i586
(Sorry to paste so much there!)
Is there an easy way to get all of those in one go or do I gotsta do it the old fashioned way?
That is a long list of dependencies, but you can filter out the duplicates.
Try this (first become root):
su
Enter your password then:
yum install libICE.so.6 libSM.so.6 libX11.so.6 libXext.so.6 libXi.so.6 libXrandr.so.2 libXrender.so.1 libc.so.6 libdl.so.2 libfontconfig.so.1 libfreetype.so.6 libgcc_s.so.1 libglib-2.0.so.0 libgthread-2.0.so.0 libm.so.6 libpng12.so.0 libpthread.so.0 librt.so.1 libstdc++.so.6 libz.so.1
See how far you get with that (not a Fedora user myself so YMMV)
Ok well it had a good whack at it but at the end of it:
Error: Multilib version problems found. This often means that the root
cause is something else and multilib version checking is just
pointing out that there is a problem. Eg.:
     1. You have an upgrade for libstdc++ which is missing some
        dependency that another package requires. Yum is trying to
        solve this by installing an older version of libstdc++ of the
        different architecture. If you exclude the bad architecture
        yum will tell you what the root cause is (which package
        requires what). You can try redoing the upgrade with
        --exclude libstdc++.otherarch ... this should give you an error
        message showing the root cause of the problem.
     2. You have multiple architectures of libstdc++ installed, but
        yum can only see an upgrade for one of those architectures.
        If you don't want/need both architectures anymore then you
        can remove the one with the missing update and everything
        will work.
     3. You have duplicate versions of libstdc++ installed already.
        You can use "yum check" to get yum show these errors.
   ...you can also use --setopt=protected_multilib=false to remove
   this checking, however this is almost never the correct thing to
   do as something else is very likely to go wrong (often causing
   much more problems).
   Protected multilib versions: libstdc++-4.8.2-1.fc19.i686 != libstdc++-4.8.1-1.fc19.x86_64
Error: Protected multilib versions: libgcc-4.8.2-1.fc19.i686 != libgcc-4.8.1-1.fc19.x86_64
Error: Protected multilib versions: freetype-2.4.11-7.fc19.i686 != freetype-2.4.11-6.fc19.x86_64
Error: Protected multilib versions: libXi-1.7.2-1.fc19.i686 != libXi-1.7.1-5.20130524git661c45ca1.fc19.x86_64
Error: Protected multilib versions: glib2-2.36.3-4.fc19.i686 != glib2-2.36.3-2.fc19.x86_64
It appears that the ones with error are already installed
First try to execute the file again and post the output
Also you could try for each package with error:
yum list installed libstdc++
yum distro-sync libstdc++
Executed the file again and got same dependancies list.
Did those two commands for each of the 5 erros and then executed file, same result.
Just downloaded the dependancies again and it has worked!
Packet Tracer installed and seems to be running so far.
Next job is to try and get the lab/tutorial files from Uni working on it!
Thank you so much for your help! I maybe bumping this later to find out how to do that lol.
Glad it worked out at the end.
