Cluster File System
Hi
Has anyone got any recommendations for a high performance replacement to NFS which will preferably run in VMware guests?
Thanks!
That all depends on whether you want a cluster filesystem, or just a network filesystem. (like NFS)
If it’s the latter, take a look at “Gluster”.
If it’s the former, unless you have a very large IT department and lots of help, forget it and look at “Gluster”.
(I’m assuming here you’ve looked at the previous post re; OCFS2 and discounted it …)
Thanks for the pointer, am taking a look at Gluster right now!
