Compiz window animations
I’ve been playing with compiz just to fancy up the desktop a bit and liked the look of the ‘burn’ animation (seen it on a you tube vid) but when I installed compiz it doesn’t seem to be in the list of available effects.
Any suggestions?
Run:
sudo apt-get install compiz-fusion-plugins-extra compiz-fusion-plugins-main
Log off and on again.
In CCSM, enable the Animations Add-On
Burn will now be listed under Animations
Yeah.
Thanx Mark, SWMBO will think she has broken the Lappy now.
If you want to change the flame colour… look in Animations Add-On (settings)
