computer start up slow (Solved)
My computer is quite slow in starting up. I have attached the bottom of the results I got from dmesg.txt.
[ 23.390556] audit: type=1400 audit(1471620033.694:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/connman/scripts/dhclient-script” pid=2228 comm=“apparmor_parser”
[ 23.391106] audit: type=1400 audit(1471620033.698:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/lightdm/lightdm-guest-session” pid=2227 comm=“apparmor_parser”
[ 23.391116] audit: type=1400 audit(1471620033.698:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/lightdm/lightdm-guest-session//chromium” pid=2227 comm=“apparmor_parser”
[ 23.397794] audit: type=1400 audit(1471620033.702:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/sbin/cups-browsed” pid=2231 comm=“apparmor_parser”
[ 23.401158] audit: type=1400 audit(1471620033.706:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/cups/backend/cups-pdf” pid=2232 comm=“apparmor_parser”
[ 23.401168] audit: type=1400 audit(1471620033.706:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/sbin/cupsd” pid=2232 comm=“apparmor_parser”
[ 23.401175] audit: type=1400 audit(1471620033.706:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/sbin/cupsd//third_party” pid=2232 comm=“apparmor_parser”
[ 27.803750] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 27.803754] Bluetooth: BNEP filters: protocol multicast
[ 27.803760] Bluetooth: BNEP socket layer initialized
[ 31.348058] IPv6: ADDRCONF(NETDEV_UP): enp3s0f2: link is not ready
[ 31.497601] r8169 0000:03:00.2 enp3s0f2: link down
[ 31.497701] IPv6: ADDRCONF(NETDEV_UP): enp3s0f2: link is not ready
[ 31.594932] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 31.976223] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 32.401313] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 41.401431] wlp2s0: authenticate with 20:0c:c8:7d:08:18
[ 41.776636] wlp2s0: send auth to 20:0c:c8:7d:08:18 (try 1/3)
[ 41.778530] wlp2s0: authenticated
[ 41.780193] wlp2s0: associate with 20:0c:c8:7d:08:18 (try 1/3)
[ 41.784401] wlp2s0: RX AssocResp from 20:0c:c8:7d:08:18 (capab=0x411 status=0 aid=2)
[ 41.784591] wlp2s0: associated
[ 41.784634] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 41.832620] cfg80211: Regulatory domain changed to country: GB
[ 41.832624] cfg80211: DFS Master region: ETSI
[ 41.832626] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 41.832629] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 41.832631] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 41.832634] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 41.832636] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 41.832638] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 938.389088] r8169 0000:03:00.2 enp3s0f2: link up
[ 938.389102] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0f2: link becomes ready
[ 1435.559193] wlp2s0: deauthenticated from 20:0c:c8:7d:08:18 (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA)
[ 1435.610257] wlp2s0: authenticate with 20:0c:c8:7d:08:18
[ 1435.623953] wlp2s0: send auth to 20:0c:c8:7d:08:18 (try 1/3)
[ 1435.625830] wlp2s0: authenticated
[ 1435.629614] wlp2s0: associate with 20:0c:c8:7d:08:18 (try 1/3)
[ 1435.633816] wlp2s0: RX AssocResp from 20:0c:c8:7d:08:18 (capab=0x411 status=0 aid=1)
[ 1435.634050] wlp2s0: associated
[ 1435.654658] cfg80211: World regulatory domain updated:
[ 1435.654663] cfg80211: DFS Master region: unset
[ 1435.654665] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1435.654668] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1435.654670] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1435.654672] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1435.654675] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1435.654678] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1435.654680] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1435.654682] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1435.654684] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1435.721485] cfg80211: Regulatory domain changed to country: GB
[ 1435.721490] cfg80211: DFS Master region: ETSI
[ 1435.721492] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1435.721495] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1435.721497] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1435.721500] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1435.721502] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 1435.721504] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Is there a problem here ? and can I fix it ?
This is where most of that time is spent:
[ 41.832638] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A) [ 938.389088] r8169 0000:03:00.2 enp3s0f2: link up [ 938.389102] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0f2: link becomes ready [ 1435.559193] wlp2s0: deauthenticated from 20:0c:c8:7d:08:18 (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA) [ 1435.610257] wlp2s0: authenticate with 20:0c:c8:7d:08:18 [ 1435.623953] wlp2s0: send auth to 20:0c:c8:7d:08:18 (try 1/3) [ 1435.625830] wlp2s0: authenticated
It may be something to do with the delay caused by trying to connect with IPV6.
Try booting with your wireless disabled and see if hat makes the difference.
If it does (it should) the re-enable the wireless and then try disabling IPV6 in your router and/or your machine and see if it is improved the boot.
Can you also define “slow to boot”, and post the output from
inxi -F
I get this
don@ldwatson ~ $ inxi -F
System: Host: ldwatson Kernel: 4.4.0-34-generic x86_64 (64 bit) Desktop: N/A Distro: Peppermint Seven
Machine: System: Notebook (portable) product: W24xCZ
Mobo: Notebook model: W24xCZ v: V3.0 Bios: American Megatrends v: 4.6.5 date: 11/18/2013
CPU: Dual core Intel Celeron 1037U (-MCP-) cache: 2048 KB
clock speeds: max: 1800 MHz 1: 799 MHz 2: 800 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller
Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa) Resolution: [email protected]
GLX Renderer: Mesa DRI Intel Ivybridge Mobile GLX Version: 3.0 Mesa 11.2.0
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.4.0-34-generic
Network: Card-1: Realtek RTL8723AE PCIe Wireless Network Adapter driver: rtl8723ae
IF: wlp2s0 state: up mac: a4:db:30:c7:44:e8
Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller driver: r8169
IF: enp3s0f2 state: down mac: 00:90:f5:f3:67:bf
Drives: HDD Total Size: 500.1GB (6.8% used) ID-1: /dev/sda model: HGST_HTS545050A7 size: 500.1GB
Partition: ID-1: / size: 455G used: 29G (7%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 3.98GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 48.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 192 Uptime: 4 min Memory: 640.3/3656.3MB Client: Shell (bash) inxi: 2.2.35
don@ldwatson ~ $
Did you try what SeZo suggested and boot with wireless disabled to see if that made a difference ? … as a diagnostic test.
and how about my other question ? … can you define “slow to boot” ?
Before I shut down last night I disabled the WiFi connection.
When I started this morning I switched the machine on and it took 45 seconds to show the login screen. I thought this was a bit long to be sat staring at a blank monitor.
I ticked the box and enabled the WiFi connection, I then shut down.
I have just restarted the computer and it took the same 45 seconds to get to the login screen.
I haven’t been to disable the IPV6 yet as I am unsure of the best way to do it.
Sorry to be such a nuisance.
take care
Don W
Try disabling the WiFi with the hardware switch rather than software (as that will only come into effect after you log in).
Also if you could post the dmesg extract with the WiFi disabled for comparison.
OK SeZo,
I will unplug the router before I power up. Is that ok?
I will need to wait as my grandson is using his machine on the WiFi to keep up with the football. lol
@ SeZo
I don’t think the bit of dmesg you’re concentrating on is part of the boot sequence … I think that’s where the system dropped wifi after the PC had been on for some time, and then reconnected (a known issue with RTL8723xx cards without a driver tweak).
I think the boot sequence ends here
and besides a 9 second wait for wireless to come up here:-
I’m not really seeing anything stupidly excessive
41 seconds isn’t a fast boot by any means, but neither is it WAY excessive for a hard drive.
@ donwatson
Has the PC always taken 41 seconds, or is this a new thing ?
turning off the router probably won’t make a difference as the wirless in your PC is still going to look for the connection … in fat it may evenslow booting further … does your BIOS have an option to disable wireless entirely, or if it’s a laptop is there a key cobo to disable wifi ?
Thanks for the info. Mark,
I think it ‘may’ have booted faster when first I installed Pep 7. I suppose the addition of all the programmes, Google and a pile of games may make it run a little slower ?
The machine is a Novatech and I ‘think’ there is a Fn+F12 that connects with the WiFi.
I have a folder on my machine that I saved from Pep 6, it is named rtlwifi-lwfinger and it had something to do with the wifi connection, I think.
Try turning off wireless with your Fn+F12 … then reboot (hopefully wireless will stay off).
Did wireless stay off when you rebooted … ie, did you need to turn it back on after the reboot ?
If so, did the PC boot any faster ?
I tried Fn+F12 but there is nothing to indicate that anything is happening. The WiFi bars stay full up and left clicking shows the WiFi Enabled is still ticked. I rebooted and it still took around 45 seconds to boot.
I am not sure that ‘ALL’ the Fn keys work on this machine. I bought the machine as a bare bones machine and installed Peppermint 5. Any problems were resolved on here by you and other members as Novatech ‘only worked with MS Windows’ ?
I know the Fn+F8,F9 increases/decreases the screen brightness the rest of the Fn keys are a mystery. I think I asked Novatech about Fn+F12 before when I had a wireless problem and that was when they said they only fixed Windows.?
take care
Don W
I’m getting reports from a “few” other people of slow boot times compared to Peppermint 6 … this only seems to affect a ery small number of people, most reporting that if anything systemd seems to have made booting FASTER.
In a topic on the Peppermint forum I’ve just asked if anyone wants to attempt switching back to upstart-sysv to see if that helps.
Wanna give it a shot ? … or do you want to wait and see what happens in the Peppermint forum ?
Reason I ask - this would be totally experimental so I cannot guarantee it’s reliability, in fact I can’t guarantee it won’t screw your system … all I can say is I’ve switched between upstart-sysv and systemd-sysv (and back again) a few times without issue.
I will give it a try. This is a fairly new install of Peppermint 7 so there is nothing to lose.
Let’s see if switching to WiCD helps first … you’re propbably going to need to do this for upstart-sysv anyway.
Open a terminal and run:
sudo apt-get install wicd
sudo apt-get remove network-manager
then reboot to test.
If there’s no wicd tray icon for configuring your network, run:
nohup wicd-gtk -t
then close the terminal
There should be a tray icon now … you’ll probably need to configure your network again there … be aware it IS different to the previous network-manager, but I’m sure you can figure it out.
Does your PC boot any faster now ?
Sorry I am so late, my computer won’t connect to the internet and I had to pick this windoze machine from my grandson.
As I said, I can’t get an Internet connection, it has a new tray icon and when I left click on it it says ’ Connected to MyAdhocNetwork at ??% (IP:169.254.12.10). As you will know I tried to get a connection but failed Is it salvageable ?
Left click the wireless icon then just click the Disconnect button under the MyAdhocNetwork and then click on the network you want to connect to (your router)
Hi SeZo,
After a while the page stops and at the bottom where the VM name is it says ‘Connection Failed:Bad password’
EDIT I have entered the passphrase from the bottom of the router and it is working now. Thanks SeZo.
I switched off and and when I switched the computer back on it only took some 30 seconds to boot to the login screen, and here I am. lol
Sorry I couldn’t come back to this until now.
Don, are you saying WiCD has improved your boot speed significantly ?
When I saw this I shut down the computer and went to fetch the stopwatch. I booted up again and it still took around 45 seconds, so no change really.
However when I got back with the watch the computer was still ‘shutting down’ and was another 30 seconds doing that. Has my computer got a life of its own ? :wink:
What next ?
