Dazzel DVC 100 Program Help?
is there any software i can use with my Dazzel DVC 100?
Try installing dvr from synaptic
sudo apt-get update && sudo apt-get install dvr
now (with the dazzle plugged in) from the terminal type:
dvr-qtgui
From what I can tell a dazzle operates as a video4linux device (webcam etc.) so any application that can record from a video4linux device should work, such as -
camorama
cheese
or even better
vlc
all of which can be installed through synaptic
thanks for that mark :).
