dcraw and The Gimp
Hi.
I’m having trouble opening my Fuji HS10 raw files in The Gimp, Ufraw, Rawtherapee etc. I noticed this post in a Fuji forum and wondered if anyone can direct me to this plugin. Read the bottom post (Final) to see what I mean…LINK myfinepix.co.uk
Thanks in advance.
Found this as well…Facebook
sudo apt-get install gimp-dcraw gimp-ufraw dcraw ufraw
Thanks I’ll try that.
After taking your suggestion Mark, I got this…
gimp-ufraw : Conflicts: gimp-dcraw but 1.31-1.1 is to be installed
E: Broken packages
Can you help?
Ignore gimp-ufraw then.
sudo apt-get install gimp-dcraw dcraw
Thanks, works a treat. :slight_smile:
