Dell 2145CN printer
Hi I have acquired a dell 2145cn printer from work and am trying to get it to work with my laptop. I am using Ubuntu 12.?? I have checked the compatibility with the link on another post in this section and found the info but cannot down load it. And once I have managed to get the drivers how do I install them?
Thanks
Mark
According to Openprinting, you just need to use the Generic PCL 5c Printer - CUPS+Gutenprint v5.2.5
So go to “Printers” … click the “Add” button
With a little luck your printer will be detected…
When asked which driver to use, select Generic > PCL 5c > Generic PCL 5c Printer - CUPS+Gutenprint v5.2.blah,blah,blah
Ok thanks. sounds too easy. I will give it a go tonight.
Thanks
Mark
