Edimax Wireless LAN
I just bought a new PC and immediately installed Ubuntu, but it can’t find any wireless networks. I assume this is because the wireless (Edimax wireless LAN, not sure of the exact name) is not supported.
How can I find the driver for this component? Is there a way to download it here (my laptop) and copy it to my new system, or will I have to use an ethernet cable?
Thanks in advance.
Could you open a terminal using Ctrl+Alt+F2 and send the out from:
sudo modprobe
lshw -C network
EDIT: Also what is the Make/Model of your PC?
sudo modprobe:
Usage: modprobe [-v] [-V] [-C config-file] [-d <dirname> ] [-n] [-i] [-q] [-b] [-o <modname>] [ --dump-modversions ] <modname> [parameters...]
modprobe -r [-n] [-i] [-v] <modulename> ...
modprobe -l -t <dirname> [ -a <modulename> ...]
lshw -C network:
  *-network
       product: RTL8191SEvB Wireless LAN Controller
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 10
       serial: 80:1f:02:2f:14:a0
       width: 32 bits
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192se driverversion=3.0.0-12-generic firmware=N/A latency=0 multicast=yes wireless=IEEE 802.11bgn
       resources: irq:16 ioport:d000(size=256) memory:fb200000-fb203fff
  *-network
       physical id: 0
       bus info: pci@0000:05:00.0
       logical name: eth0
       version: 03
       serial: f4:6d:04:7c:ad:82
       capacity: 1Gbit/s
       width: 64 bits
       capabilities: bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8168d-2.fw latency=0 multicast=yes port=MII speed=10Mbit/s
       resources: irq:50 ioport:c000(size=256) memory:f2104000-f2104fff memory:f2100000-f2103fff memory:f2110000-f211ffff
It told me to run as sudo, which I did, and it crashed twice (I could not file the bug report as I have no internet :frowning: )
The third time I ran it I got:
Segmentation fault (core dumped)
The PC is custom built by computerplanet.co.uk, intel processor, Asus P8H67-M (LE), running ubuntu 11.10 liveUSB.
It’s worth mentioning that earlier today I’d had the computer on running the live version for quite a while and it found a network (not mine unfortunately) but since I restarted it has lost it again.
Can you post the output from
ifconfig
sudo iwlist scanning
ifconfig:
eth0      Link encap:Ethernet  HWaddr f4:6d:04:7c:ad:82
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:50
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:88 errors:0 dropped:0 overruns:0 frame:0
          TX packets:88 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:4880 (4.8 KB)  TX bytes:4880 (4.8 KB)
wlan0     Link encap:Ethernet  HWaddr 80:1f:02:2f:14:a0
sudo iwlist scanning:
wlan0     No scan results
update: it’s found the other network again, much like last time - I left it on for a long time and it appeared under the network appindicator, the same network as last time.
Are you saying it’s fixed itself or not ?
I wouldn’t say fixed - firstly it takes about half an hour to find it, and secondly it doesn’t find my home network so I still can’t get online. So it’s just a different problem. Incidently the network it has found is called ‘badger’, and I can see it on my other (this) machine, and there doesn’t seem to be anything unusual about it, so is there any reason it should find this netowkr but none of the others?
Which version of Ubuntu ?
God knows why it sees that one… maybe it’s using WEP rather than WPA/2 or is unencrypted
This is Ubuntu 11.10 from a live USB - the specs on my network card say it can handle WPA WPA2 and WEP 64 and 128 bit, and the network is definitely encrypted.
Damn … I’d already typed up the instructions for 11.04 … now I discover the driver needs modifying before it will compile in 11.10 :o
Anyway, I’ve pre-modified the driver for 11.10 and uploaded it to my dropbox.
(for future readers, this driver is for 11.10 only and may not compile in previous Ubuntu versions)
So try this…
cd ~
wget http://dl.dropbox.com/u/11876059/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011.tar.gz
tar -xzvf rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011.tar.gz
cd ~/rtl_92ce_92se_92de_linux_mac80211_0004.0816.2011
sudo su
make
make install
exit
then to reload the driver:
sudo modprobe -r rtl8192se
sudo modprobe rtl8192se
Now check if your Wireless is now working
If it is working … REBOOT, and check it STILL works.
Hmmm, still not working. When I ran that last command (sudo modprobe rtl8192se) I got a notifyOSD saying Network: disconnected - you are now offline.
Is there anything else I can try?
can you send the output from:
rfkill list
0:  phy0:  Wireless LAN
         Soft blocked: no
         Hard blocked: no
What does -
sudo lshw -C network
ifconfig
iwlist scanning
lsmod | grep rtl
say now ?
can you also post the output from -
lspci -vnnn
modinfo rtl8192se
sudo lshw -C network still gets me nothing and a crash, but first some text comes up:
PCI (sysfs)
this is replaced by:
SCSI
which in turn disappears and I get a new prompt (and a crash, as I said). This was the same before, but I didn’t manage to write it down.
without the sudo gives me:
  *-network
       physical id: 0
       logical name: wlan0
       version: 10
       width: 32 bits
  *-network
       physical id: 0
       logical name: eth0
       version: 03
       capacity: 1Gbit/s
       width: 64 bits
ubuntu@ubuntu:~$ lshw -C network
  *-network
       physical id: 0
       logical name: wlan0
       version: 10
       width: 32 bits
  *-network
       physical id: 0
       logical name: eth0
       version: 03
       capacity: 1Gbit/s
       width: 64 bits
ifconfig:
          Interrupt:50 Base address:0x2000
iwlist scanning:
lsmod | grep rtl:
rtl8192se              99931  0
rtlwifi               110972  1 rtl8192se
mac80211              310872  2 rtl8192se,rtlwifi
cfg80211              199587  2 rtlwifi,mac80211
lspci -vnnn:
00:00.0 Host bridge [0600]: Intel Corporation 2nd Generation Core Processor Family DRAM Controller [8086:0100] (rev 09)
	Subsystem: ASUSTeK Computer Inc. P8P67 Deluxe Motherboard [1043:844d]
	Flags: bus master, fast devsel, latency 0
	Capabilities: <access denied>
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port [8086:0101] (rev 09) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 0000e000-0000efff
	Memory behind bridge: fa000000-fb0fffff
	Prefetchable memory behind bridge: 00000000e8000000-00000000f1ffffff
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:16.0 Communication controller [0780]: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 [8086:1c3a] (rev 04)
	Flags: bus master, fast devsel, latency 0, IRQ 21
	Memory at fb307000 (64-bit, non-prefetchable) [size=16]
	Kernel driver in use: mei
	Kernel modules: mei
00:1a.0 USB Controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 [8086:1c2d] (rev 05) (prog-if 20 [EHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 23
	Memory at fb306000 (32-bit, non-prefetchable) [size=1K]
	Kernel driver in use: ehci_hcd
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 05)
	Subsystem: ASUSTeK Computer Inc. Device [1043:840b]
	Flags: bus master, fast devsel, latency 0, IRQ 51
	Memory at fb300000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: HDA Intel
	Kernel modules: snd-hda-intel
00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b5) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: fb200000-fb2fffff
00:1c.4 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev b5) (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=03, subordinate=04, sec-latency=0
00:1c.5 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 [8086:1c1a] (rev b5) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff
	Memory behind bridge: e4000000-e40fffff
	Prefetchable memory behind bridge: 00000000f2100000-00000000f21fffff
00:1c.6 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 [8086:1c1c] (rev b5) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
	Memory behind bridge: fb100000-fb1fffff
00:1c.7 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 [8086:1c1e] (rev b5) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
00:1d.0 USB Controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 [8086:1c26] (rev 05) (prog-if 20 [EHCI])
	Memory at fb305000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge [0601]: Intel Corporation H67 Express Chipset Family LPC Controller [8086:1c4a] (rev 05)
	Subsystem: ASUSTeK Computer Inc. Device [1043:844d]
	Kernel modules: iTCO_wdt
00:1f.2 IDE interface [0101]: Intel Corporation 6 Series/C200 Series Chipset Family 4 port SATA IDE Controller [8086:1c00] (rev 05) (prog-if 8f [Master SecP SecO PriP PriO])
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 20
	I/O ports at f0d0 [size=8]
	I/O ports at f0c0 [size=4]
	I/O ports at f0b0 [size=8]
	I/O ports at f0a0 [size=4]
	I/O ports at f090 [size=16]
	I/O ports at f080 [size=16]
	Kernel driver in use: ata_piix
00:1f.3 SMBus [0c05]: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller [8086:1c22] (rev 05)
	Flags: medium devsel, IRQ 4
	Memory at fb304000 (64-bit, non-prefetchable) [size=256]
	I/O ports at f000 [size=32]
	Kernel modules: i2c-i801
00:1f.5 IDE interface [0101]: Intel Corporation 6 Series/C200 Series Chipset Family 2 port SATA IDE Controller [8086:1c08] (rev 05) (prog-if 85 [Master SecO PriO])
	I/O ports at f070 [size=8]
	I/O ports at f060 [size=4]
	I/O ports at f050 [size=8]
	I/O ports at f040 [size=4]
	I/O ports at f030 [size=16]
	I/O ports at f020 [size=16]
01:00.0 VGA compatible controller [0300]: nVidia Corporation GF108 [GeForce GT 430] [10de:0de1] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: eVga.com. Corp. Device [3842:1335]
	Flags: bus master, fast devsel, latency 0, IRQ 16
	Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
	Memory at e8000000 (64-bit, prefetchable) [size=128M]
	Memory at f0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at e000 [size=128]
	Expansion ROM at fb000000 [disabled] [size=512K]
	Kernel driver in use: nouveau
	Kernel modules: nouveau, nvidiafb
01:00.1 Audio device [0403]: nVidia Corporation GF108 High Definition Audio Controller [10de:0bea] (rev a1)
	Flags: bus master, fast devsel, latency 0, IRQ 17
	Memory at fb080000 (32-bit, non-prefetchable) [size=16K]
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8191SEvB Wireless LAN Controller [10ec:8172] (rev 10)
	Subsystem: Edimax Computer Co. Device [1432:7612]
	I/O ports at d000 [size=256]
	Memory at fb200000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: rtl8192se
	Kernel modules: rtl8192se
03:00.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1080] (rev 01) (prog-if 01 [Subtractive decode])
	Bus: primary=03, secondary=04, subordinate=04, sec-latency=32
05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 03)
	Subsystem: ASUSTeK Computer Inc. M4A785TD Motherboard [1043:83a3]
	Flags: bus master, fast devsel, latency 0, IRQ 50
	I/O ports at c000 [size=256]
	Memory at f2104000 (64-bit, prefetchable) [size=4K]
	Memory at f2100000 (64-bit, prefetchable) [size=16K]
	Expansion ROM at f2110000 [disabled] [size=64K]
	Kernel driver in use: r8169
	Kernel modules: r8169
06:00.0 USB Controller [0c03]: NEC Corporation uPD720200 USB 3.0 Host Controller [1033:0194] (rev 04) (prog-if 30 [XHCI])
	Subsystem: ASUSTeK Computer Inc. P8P67 Deluxe Motherboard [1043:8413]
	Flags: bus master, fast devsel, latency 0, IRQ 18
	Memory at fb100000 (64-bit, non-prefetchable) [size=8K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci-hcd
modinfo rtl8192se:
filename:       /lib/modules/3.0.0-12-generic/kernel/drivers/net/wireless/rtlwifi/rtl8192se/rtl8192se.ko
firmware:       rtlwifi/rtl8192sefw.bin
description:    Realtek 8192S/8191S 802.11n PCI wireless
license:        GPL
author:         Realtek WlanFAE	<[email protected]>
author:         lizhaoming	<[email protected]>
srcversion:     937F4C8CF0D06038BBDF950
alias:          pci:v000010ECd00008174sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008173sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008172sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008171sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008192sv*sd*bc*sc*i*
depends:        rtlwifi,mac80211
vermagic:       3.0.0-12-generic SMP mod_unload modversions
parm:           fwlps:bool
parm:           swenc:using hardware crypto (default 0 [hardware])
 (bool)
parm:           ips:using no link power save (default 1 is open)
 (bool)
parm:           swlps:using linked sw control power save (default 1 is open)
 (bool)
So what exactly is the problem ? … is it still not showing any available networks in networkmanager ?
No, although as I said it has shown a network called ‘badger’ on two occasions (both yesterday, on separate boots, after being on for about an hour and on neither occasion disappearing until after the computer has shut down).
I have no idea what the problem is.
Searching for a solution … problem is Realtek haven’t got round to doing any drivers for kernels >= 2.6.39
Well this changes everything:
I just took the computer to the room with the router, and it picks it up. I guess that means the problem was just that the signal was too weak where I was - but my five year old laptop does fine there. However even in the room with good signal, I can’t log in - I enter the password which I know is correct but it doesn’t give me access. I am on now using a wire, and will install now, but there now seem to be too problems - it’s rubbish at picking up the signal, and it won’t log in.
I will update later.
