Error with kernel installation of 2.6.25 on Fedora13 [2.6.33.3-85.fc13.i686.PAE]
Hello groupmates,
I followed below steps:
  1. downloaded and tar the linux kernel version 2.6.25
  2. patched with tproxy(for transparent proxying support)
  3. make mrproper
  4. make config(selected default options mostly)
  5. make -j 4 && make modules_install && make install
I am getting following error:
ERROR: modinfo: could not found module snd_hda_codec_realtek
ERROR: modinfo: could not found module dell_wmi
ERROR: modinfo: could not found module drm_kms_helper
grubby fatal error: unable to find a suitable template
How can i resolve the above errors. Any help would be highly appreciative.
Thank you.
-Ashutosh.
At what point do you get these errors?
Also, where did you get the kernel from?
That is an ancient kernel, btw :o
