Filesharing between Linux & Window$ - HOW
I recently took the plunge and replaced mine & Mrs pookys old second-hand Window$ laptops and bought new ones. I had the full intention of wiing Window$ and installing Kubuntu on both but (yes, there had to be a but). It’s kinda grown on us so, we decided to leave Window$ on and make them dual-boot systems. The only problem there is, I have no idea how to make them dual-boot systems.
I know this is ‘Shared Filesystems’ forum but that was just a little history.
I have a Kubuntu 14.04 Desktop and I want to be able to share files between the desktop and the 2 laptops, also between the 2 laptops themselves.
Can anyone give me step-by-step instructions please?
Forgot to mention, the first obstacle I encountered was the UEFI one. I tried switching it off in BIOS but it seems I was unsucessful.
I have got an HP Pavilion Intel Core i5-7200U CPU 2.5Ghz 2.71Ghz 8Gb Ram
So what exactly is the problem ?
In your file manager if you go to “network” (network:///), is the network not browsable ?
Have you actually shared any folders in either Windows or Linux) ?
and where does UEFI come into this ?
I don’t know how to go about setting up sharing between Win & Ubuntu
I typed in ‘network///’ and I got a message ‘You’ll need a new app to open this network’
(If you’ve not figured, I’m using Window$10)
No, that’s why I am asking for help.
If you read what I wrote correctly, you will see why I mentioned UEFI. It has NOTHING to do with the networking problem, after the first paragraph, I wrote;
I’ve created a new thread for that problem.
I know sod all about KDE, but if you install kdenetwork-filesharing and samba
sudo apt-get install samba kdenetwork-filesharing
then log off/on (or reboot)
When you right-click on a folder in your home folder such as “Public” and select “Properties”, do you have a “Sharing” tab ?
samba kdenetwork-filesharing was already installed
And, yes, there IS a ‘Share’ Tab.
What next? (I’m just being cautious).
As I said, I know sod all about KDE so you’re gonna a have to help me out here with either an explanation of the options available or a screenshot.
'Fraid I don’t even know where to start.
A screenshot of a folders “Properties” > “Share” tab would be a good start.
I decided to Google the problem and found THIS.
I Haven’t attempted to set up sharing from Window$ to Kubuntu yet, so the problem is HALF solved.
I have a screenshot for you, Mark, if it will help.
Not got it working properly yet, it’s downloading the screenshot instead of opening it in a browser window
Screenshot Here
It’s working OK now.
Could you recommend a good online storage that is free and will let me display the image in a forum rather than open another page like I’m currently using. I did use Imageshack but they went to subscription only.
Host images on IMGUR
http://imgur.com
then you can just post the URL between IMG tags and the image will display in the forum.
