Fix Memory sticks [thanks anyway]
is there a utility to fix memory sticks
Yes, it’s called Super Glue :wink: … You’ll have to give us more than that… What’s wrong with it ?
Taken out and not unmounted properly, I’ve gut them with windows and linux ?
Is the USB stick recognised when you plug it into Linux or Windows ?
Are there any error messages in either OS ?
No there never are on either operating system
Plug it in, and in Linux, post the output from these 3 commands
dmesg | tail
lsusb
sudo fdisk -l
This is the output
gordon@gordon-desktop:~$ dmesg | tail
[ 13.340608] e1000e 0000:00:19.0: irq 45 for MSI/MSI-X
[ 13.340888] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.286989] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[ 14.756857] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 14.756862] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 14.757084] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.230235] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
[ 25.040004] eth0: no IPv6 routers present
[ 181.156027] hub 7-0:1.0: over-current change on port 1
[ 181.260027] hub 7-0:1.0: over-current change on port 2
gordon@gordon-desktop:~$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 192f:0716 Avago Technologies, Pte.
gordon@gordon-desktop:~$ sudo fdisk -l
[sudo] password for gordon:
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Disk identifier: 0x0001865f
/dev/sda1 * 1 9347 75078656 83 Linux
/dev/sda2 9348 9730 3069953 5 Extended
/dev/sda5 9348 9730 3069952 82 Linux swap / Solaris
Well if you had the USB stick plugged in when you ran those… the stick is DEAD, as it’s not being detected AT ALL.
