Flash updating (SOLVED)
Hi,
I use Chrome (mostly) and I am meeting some problems when trying to use some websites.
I try to log on but the site says I need the latest Flash Player version ??
I update daily using the Update Manager (when there are updates) and I thought Flash Player would be included.
How do I updated Flash Player.
I had a look at the post from Mel and have started with this
don@ldwatson ~ $ dpkg -l | grep flash
ii flashplugin-installer
What do I do next ?
Hi Don, if you use Chrome, the flashplayer should be included … are you sure you’re using Chrome, and not Chromium ?
Can we have the FULL output from:
dpkg -l | grep google-chrome
uname -a
I have this
don@ldwatson ~ $ dpkg -l | grep google-chrome
ii google-chrome-stable 61.0.3163.100-1 amd64 The web browser from Google
ii flashplugin-installer 27.0.0.130ubuntu0.16.04.1 amd64 Adobe Flash Player plugin installer
don@ldwatson ~ $ uname -a
Linux ldwatson 4.4.0-96-generic #119-Ubuntu SMP Tue Sep 12 14:59:54 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
don@ldwatson ~ $
Is this ok ?
Can you give me a sample URL that’s giving you the update flash message ?
When I try here it says to get updated
http://www.broxburnwoodcraftclub.org/
I also get it here
Don W
In Chrome, if you go to
chrome://flash
what is displayed ?
Can I copy and paste it here ?
Sure :slight_smile:
About Flash
Google Chrome	61.0.3163.100 ()
OS	Linux
Flash plugin	27.0.0.130 /home/don/.config/google-chrome/PepperFlash/27.0.0.130/libpepflashplayer.so
--- Crash data ---
Crash Reporting	Enable crash reporting to see crash IDs
For more details	https://support.google.com/chrome/?p=ui_usagestat
--- GPU information ---
--- GPU driver, more information ---
Vendor Id	0x8086
Device Id	0x0156
Driver vendor	Mesa
Driver version	17.0.7
Driver date
Pixel shader version	3.30
Vertex shader version	3.30
GL_VENDOR	Intel Open Source Technology Center
GL_RENDERER	Mesa DRI Intel(R) Ivybridge Mobile
GL_VERSION	3.3 (Core Profile) Mesa 17.0.7
GL_EXTENSIONS	GL_3DFX_texture_compression_FXT1 GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_trinary_minmax GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_object_purgeable GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gpu_shader5 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map_array GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ATI_blend_equation_separate GL_ATI_texture_float GL_EXT_abgr GL_EXT_blend_equation_separate GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_shader_integer_mix GL_EXT_shader_samples_identical GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_KHR_context_flush_control GL_KHR_debug GL_KHR_robustness GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_NV_conditional_render GL_NV_depth_clamp GL_NV_packed_depth_stencil GL_NV_texture_barrier GL_OES_EGL_image GL_S3_s3tc
Okay let’s try forcing Chrome to re-download it’s pepperflash player…
WITH CHROME CLOSED:-
Open a terminal and run:
sudo rm -rv ~/.config/google-chrome/PepperFlash
Now open Chrome and go to:-
you should see a jigsaw piece at the top saying “Downloading”, followed by “Restart Chrome to enable Abobe Flash Player
Close Chrome, reopen Chrome, and test again here:
That has cured the problem with the Broxburn site.
I still have an issue with
Does pressing F5 whilst on the
page make it reload and work ?
No.
Could that be my Ad Blocker causing this ? I useAdblockPlus
I doubt it, I just installed ABP and the site still works for me.
Maybe try clearing the browser cache … then restart Chrome.
Sorry Mark,
It still does not work on that site.
I can forget the site if that is ok. It is an American wood site and useless for me.
Strange because it’s working for me in Chrome (same version as you) … maybe try disabling all plugins (as a test).
Or there’s always Chromium or Firefox :wink:
Thanks Mark,
It works in Firefox.
I never thought to try Firefox but there you are, me missing the obvious as usual :-[
Great news :slight_smile:
