Fresh install (Kubuntu 14.04) and unable to read DVD's
I have done a fresh install of Kubuntu 14.04 and installed the Kubuntu restricted extras package.
I want to back up my DVD collection and have installed Brassero/K3b/Handbrake but I’m unable to copy any DVD.
When I use K3b, I get ‘Unable to read Video DVD contents: Found encrypted Video DVD.
Install libdvdcss to get Video DVD decryption support.
I have checked that it is installed, in Muon Package Manager, I searched for ‘libdvdscc’ and it comes up with ‘libdvdread4’ installed but no sign of ‘libdvdscc’. Is that the same thing?
How do I check that I have whatever is needed to copy the DVD’s installed?
If you’ve installed libdvdread4, now open a terminal and run:
sudo /usr/share/doc/libdvdread4/install-css.sh
They’ve made this easier in16.04 … where you just need to install libdvd-pkg
I use K9Copy reloaded with Mint 17 & Mint 17.1, works a treat.
http://tomtomtom.org/k9copy-reloaded/en.html
Done that, then tried again with K3b and then got an error that ‘transcode’ was needed, which I installed.
I then tried to get K3b to read the DVD again and… IT WORKED!
Thanks Mark ;D
It (transcode) failed Mark.
This is the debug output;
Devices
ATAPI iHAS122 E 2L04 (/dev/sr0, CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL) [DVD-ROM, DVD-R Sequential, DVD-R Dual Layer Sequential, DVD-R Dual Layer Jump, DVD-RAM, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Restricted Overwrite, Layer Jump] [%7]
System
K3b Version: 2.0.2
KDE Version: 4.14.13
QT Version: 4.8.6
Kernel: 3.19.0-58-generic
Used versions
transcode: 1.1.7
transcode
transcode v1.1.7 (C) 2001-2003 Thomas Oestreich, 2003-2010 Transcode Team
[e[34;1mdvd_reader.ce[0m] DVD title 1/8: 19 chapter(s), 1 angle(s), title set 1
[e[34;1mdvd_reader.ce[0m] title playback time: 01:50:13.09 6614 sec
[transcode] V: auto-probing | /dev/sr0 (OK)
[transcode] V: import format | MPEG 2 program stream in DVD PAL (module=dvd)
[transcode] A: auto-probing | /dev/sr0 (OK)
[transcode] A: import format | AC3 in DVD PAL (module=dvd)
[transcode] V: AV demux/sync | (1) sync AV at initial MPEG sequence
[transcode] V: import frame | 720x576 1.25:1 encoded @ 16:9
[transcode] V: clip frame (<-) | 720x576
[transcode] V: zoom | 1024x576 1.78:1 (Lanczos3)
[transcode] V: bits/pixel | 0.081 (low)
[transcode] V: decoding fps,frc | 25.000,3
[transcode] V: multi-pass | (mode=1) writing data (pass 1) to /tmp/kde-pooky2483/k3b_0.log
[transcode] V: video format | YUV420 (4:2:0) aka I420
[transcode] A: import format | 0x2000 AC3 [48000,16,2]
[transcode] A: export | disabled
[transcode] V: encoding fps,frc | 25.000,3
[transcode] A: language | en
[transcode] A: bytes per frame | 7680 (7680.000000)
[transcode] A: adjustment | 0@1000
[transcode] V: IA32/AMD64 accel | sse4a sse3 sse2 sse 3dnowext 3dnow mmxext mmx cmove asm
[transcode] V: video buffer | 10 @ 1024x576 [0x2]
[transcode] A: audio buffer | 10 @ 48000x2x16
[import_dvd.so] v0.4.1 (2007-07-15) (video) DVD | (audio) MPEG/AC3/PCM
[export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null
[export_ffmpeg.so] v0.3.18 (2008-11-29) (video) Lavc54.35.0 | (audio) MPEG/AC3/PCM
[import_dvd.so] tccat -T 1,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 2 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 2 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 1,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x82 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[import_dvd.so] delaying DVD access by 3 seconds
[import_dvd.so] waiting…
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a long time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000132
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x0000022b
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00039e5f
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x0028c2cb
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x0028c373
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x003eb66e
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x003eb716
libdvdread: Found 3 VTS’s
=== last message repeated 2 times. ===
[export_ffmpeg.so] Using FFMPEG codec ‘mpeg4’ (FourCC ‘DIVX’, MPEG4 compliant video).
[export_ffmpeg.so] No profile selected
[export_ffmpeg.so] Error opening configuration file ./ffmpeg.cfg: No such file or directory
[export_ffmpeg.so] Starting 1 thread(s)
[export_ffmpeg.so] Set display aspect ratio to input
[mpeg4 @ 0x13fb420] removing common factors from framerate
[e[34;1mdecode_mpeg2.ce[0m] libmpeg2 acceleration: 3dnow
encoding=1 frame=1102 first=0 last=-1 fps=84.457 done=-1.000000 timestamp=44.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2204 first=0 last=-1 fps=82.836 done=-1.000000 timestamp=88.160 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=3306 first=0 last=-1 fps=82.157 done=-1.000000 timestamp=132.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4408 first=0 last=-1 fps=80.532 done=-1.000000 timestamp=176.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5510 first=0 last=-1 fps=79.928 done=-1.000000 timestamp=220.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6612 first=0 last=-1 fps=79.892 done=-1.000000 timestamp=264.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7714 first=0 last=-1 fps=79.622 done=-1.000000 timestamp=308.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8816 first=0 last=-1 fps=79.294 done=-1.000000 timestamp=352.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9918 first=0 last=-1 fps=79.355 done=-1.000000 timestamp=396.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11020 first=0 last=-1 fps=79.057 done=-1.000000 timestamp=440.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12122 first=0 last=-1 fps=78.908 done=-1.000000 timestamp=484.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13224 first=0 last=-1 fps=78.980 done=-1.000000 timestamp=528.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14326 first=0 last=-1 fps=79.050 done=-1.000000 timestamp=573.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=15428 first=0 last=-1 fps=79.104 done=-1.000000 timestamp=617.120 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=16530 first=0 last=-1 fps=79.123 done=-1.000000 timestamp=661.200 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=17632 first=0 last=-1 fps=79.220 done=-1.000000 timestamp=705.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18734 first=0 last=-1 fps=79.299 done=-1.000000 timestamp=749.360 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=19836 first=0 last=-1 fps=79.459 done=-1.000000 timestamp=793.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20938 first=0 last=-1 fps=79.550 done=-1.000000 timestamp=837.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=22040 first=0 last=-1 fps=79.607 done=-1.000000 timestamp=881.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=23142 first=0 last=-1 fps=79.770 done=-1.000000 timestamp=925.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=24244 first=0 last=-1 fps=79.862 done=-1.000000 timestamp=969.760 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=25346 first=0 last=-1 fps=79.939 done=-1.000000 timestamp=1013.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=26448 first=0 last=-1 fps=79.993 done=-1.000000 timestamp=1057.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=27550 first=0 last=-1 fps=80.085 done=-1.000000 timestamp=1102.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=28652 first=0 last=-1 fps=80.116 done=-1.000000 timestamp=1146.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=29754 first=0 last=-1 fps=80.098 done=-1.000000 timestamp=1190.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=30856 first=0 last=-1 fps=80.088 done=-1.000000 timestamp=1234.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=31958 first=0 last=-1 fps=80.090 done=-1.000000 timestamp=1278.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=33060 first=0 last=-1 fps=80.140 done=-1.000000 timestamp=1322.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=34162 first=0 last=-1 fps=80.125 done=-1.000000 timestamp=1366.480 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=35264 first=0 last=-1 fps=79.998 done=-1.000000 timestamp=1410.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=36366 first=0 last=-1 fps=79.919 done=-1.000000 timestamp=1454.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=37468 first=0 last=-1 fps=79.881 done=-1.000000 timestamp=1498.720 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=38570 first=0 last=-1 fps=79.471 done=-1.000000 timestamp=1542.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=39672 first=0 last=-1 fps=79.333 done=-1.000000 timestamp=1586.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=40774 first=0 last=-1 fps=79.254 done=-1.000000 timestamp=1630.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=41876 first=0 last=-1 fps=79.267 done=-1.000000 timestamp=1675.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=42978 first=0 last=-1 fps=79.174 done=-1.000000 timestamp=1719.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=44080 first=0 last=-1 fps=79.136 done=-1.000000 timestamp=1763.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=45182 first=0 last=-1 fps=79.189 done=-1.000000 timestamp=1807.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=46284 first=0 last=-1 fps=79.203 done=-1.000000 timestamp=1851.360 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=47386 first=0 last=-1 fps=79.195 done=-1.000000 timestamp=1895.440 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=48488 first=0 last=-1 fps=79.116 done=-1.000000 timestamp=1939.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=49590 first=0 last=-1 fps=79.151 done=-1.000000 timestamp=1983.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=50692 first=0 last=-1 fps=79.190 done=-1.000000 timestamp=2027.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=51794 first=0 last=-1 fps=79.208 done=-1.000000 timestamp=2071.760 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=52896 first=0 last=-1 fps=79.206 done=-1.000000 timestamp=2115.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=53998 first=0 last=-1 fps=79.064 done=-1.000000 timestamp=2159.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=55100 first=0 last=-1 fps=78.911 done=-1.000000 timestamp=2204.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=56202 first=0 last=-1 fps=78.798 done=-1.000000 timestamp=2248.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=57304 first=0 last=-1 fps=78.724 done=-1.000000 timestamp=2292.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=58406 first=0 last=-1 fps=78.727 done=-1.000000 timestamp=2336.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=59508 first=0 last=-1 fps=78.613 done=-1.000000 timestamp=2380.320 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=60610 first=0 last=-1 fps=78.594 done=-1.000000 timestamp=2424.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=61712 first=0 last=-1 fps=78.660 done=-1.000000 timestamp=2468.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=62814 first=0 last=-1 fps=78.691 done=-1.000000 timestamp=2512.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=63916 first=0 last=-1 fps=78.712 done=-1.000000 timestamp=2556.640 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=65018 first=0 last=-1 fps=78.774 done=-1.000000 timestamp=2600.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=66120 first=0 last=-1 fps=78.782 done=-1.000000 timestamp=2644.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=67222 first=0 last=-1 fps=78.825 done=-1.000000 timestamp=2688.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=68324 first=0 last=-1 fps=78.840 done=-1.000000 timestamp=2732.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=69426 first=0 last=-1 fps=78.865 done=-1.000000 timestamp=2777.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=70528 first=0 last=-1 fps=78.876 done=-1.000000 timestamp=2821.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=71630 first=0 last=-1 fps=78.921 done=-1.000000 timestamp=2865.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=72732 first=0 last=-1 fps=78.824 done=-1.000000 timestamp=2909.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=73834 first=0 last=-1 fps=78.756 done=-1.000000 timestamp=2953.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=74936 first=0 last=-1 fps=78.741 done=-1.000000 timestamp=2997.440 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=76038 first=0 last=-1 fps=78.680 done=-1.000000 timestamp=3041.520 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=77140 first=0 last=-1 fps=78.708 done=-1.000000 timestamp=3085.600 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=78242 first=0 last=-1 fps=78.746 done=-1.000000 timestamp=3129.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=79344 first=0 last=-1 fps=78.743 done=-1.000000 timestamp=3173.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=80446 first=0 last=-1 fps=78.707 done=-1.000000 timestamp=3217.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=81548 first=0 last=-1 fps=78.683 done=-1.000000 timestamp=3261.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=82650 first=0 last=-1 fps=78.652 done=-1.000000 timestamp=3306.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=83752 first=0 last=-1 fps=78.500 done=-1.000000 timestamp=3350.080 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=84854 first=0 last=-1 fps=78.523 done=-1.000000 timestamp=3394.160 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=85956 first=0 last=-1 fps=78.515 done=-1.000000 timestamp=3438.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=87058 first=0 last=-1 fps=78.482 done=-1.000000 timestamp=3482.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=88160 first=0 last=-1 fps=78.340 done=-1.000000 timestamp=3526.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=89262 first=0 last=-1 fps=78.292 done=-1.000000 timestamp=3570.480 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=90364 first=0 last=-1 fps=78.330 done=-1.000000 timestamp=3614.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=91466 first=0 last=-1 fps=78.286 done=-1.000000 timestamp=3658.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=92568 first=0 last=-1 fps=78.258 done=-1.000000 timestamp=3702.720 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=93670 first=0 last=-1 fps=78.261 done=-1.000000 timestamp=3746.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=94772 first=0 last=-1 fps=78.152 done=-1.000000 timestamp=3790.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=95874 first=0 last=-1 fps=78.054 done=-1.000000 timestamp=3834.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=96976 first=0 last=-1 fps=78.076 done=-1.000000 timestamp=3879.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=98078 first=0 last=-1 fps=78.087 done=-1.000000 timestamp=3923.120 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=99180 first=0 last=-1 fps=78.037 done=-1.000000 timestamp=3967.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=100282 first=0 last=-1 fps=78.033 done=-1.000000 timestamp=4011.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=101384 first=0 last=-1 fps=78.057 done=-1.000000 timestamp=4055.360 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=102486 first=0 last=-1 fps=78.042 done=-1.000000 timestamp=4099.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=103588 first=0 last=-1 fps=78.042 done=-1.000000 timestamp=4143.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=104690 first=0 last=-1 fps=78.036 done=-1.000000 timestamp=4187.600 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=105792 first=0 last=-1 fps=78.060 done=-1.000000 timestamp=4231.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=106894 first=0 last=-1 fps=78.050 done=-1.000000 timestamp=4275.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=107996 first=0 last=-1 fps=78.076 done=-1.000000 timestamp=4319.840 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=109098 first=0 last=-1 fps=78.077 done=-1.000000 timestamp=4363.920 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=110200 first=0 last=-1 fps=78.033 done=-1.000000 timestamp=4408.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=111302 first=0 last=-1 fps=78.016 done=-1.000000 timestamp=4452.080 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=112404 first=0 last=-1 fps=78.022 done=-1.000000 timestamp=4496.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=113506 first=0 last=-1 fps=78.023 done=-1.000000 timestamp=4540.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=114608 first=0 last=-1 fps=78.029 done=-1.000000 timestamp=4584.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=115710 first=0 last=-1 fps=78.032 done=-1.000000 timestamp=4628.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=116812 first=0 last=-1 fps=78.034 done=-1.000000 timestamp=4672.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=117914 first=0 last=-1 fps=78.049 done=-1.000000 timestamp=4716.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=119016 first=0 last=-1 fps=78.049 done=-1.000000 timestamp=4760.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=120118 first=0 last=-1 fps=77.958 done=-1.000000 timestamp=4804.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=121220 first=0 last=-1 fps=77.831 done=-1.000000 timestamp=4848.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=122322 first=0 last=-1 fps=77.789 done=-1.000000 timestamp=4892.880 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=123424 first=0 last=-1 fps=77.750 done=-1.000000 timestamp=4936.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=124526 first=0 last=-1 fps=77.752 done=-1.000000 timestamp=4981.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=125628 first=0 last=-1 fps=77.776 done=-1.000000 timestamp=5025.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=126730 first=0 last=-1 fps=77.802 done=-1.000000 timestamp=5069.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=127832 first=0 last=-1 fps=77.852 done=-1.000000 timestamp=5113.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=128934 first=0 last=-1 fps=77.888 done=-1.000000 timestamp=5157.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=130036 first=0 last=-1 fps=77.915 done=-1.000000 timestamp=5201.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=131138 first=0 last=-1 fps=77.936 done=-1.000000 timestamp=5245.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=132240 first=0 last=-1 fps=77.961 done=-1.000000 timestamp=5289.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=133342 first=0 last=-1 fps=77.991 done=-1.000000 timestamp=5333.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=134444 first=0 last=-1 fps=78.007 done=-1.000000 timestamp=5377.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=135546 first=0 last=-1 fps=78.044 done=-1.000000 timestamp=5421.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=136648 first=0 last=-1 fps=78.080 done=-1.000000 timestamp=5465.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=137750 first=0 last=-1 fps=78.111 done=-1.000000 timestamp=5510.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=138852 first=0 last=-1 fps=78.123 done=-1.000000 timestamp=5554.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=139954 first=0 last=-1 fps=78.148 done=-1.000000 timestamp=5598.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=141056 first=0 last=-1 fps=78.173 done=-1.000000 timestamp=5642.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=142158 first=0 last=-1 fps=78.191 done=-1.000000 timestamp=5686.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=143260 first=0 last=-1 fps=78.224 done=-1.000000 timestamp=5730.400 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=144362 first=0 last=-1 fps=78.249 done=-1.000000 timestamp=5774.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=145464 first=0 last=-1 fps=78.275 done=-1.000000 timestamp=5818.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=146566 first=0 last=-1 fps=78.322 done=-1.000000 timestamp=5862.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=147668 first=0 last=-1 fps=78.342 done=-1.000000 timestamp=5906.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=148770 first=0 last=-1 fps=78.365 done=-1.000000 timestamp=5950.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=149872 first=0 last=-1 fps=78.390 done=-1.000000 timestamp=5994.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=150974 first=0 last=-1 fps=78.414 done=-1.000000 timestamp=6038.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=152076 first=0 last=-1 fps=78.424 done=-1.000000 timestamp=6083.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=153178 first=0 last=-1 fps=78.464 done=-1.000000 timestamp=6127.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=154280 first=0 last=-1 fps=78.486 done=-1.000000 timestamp=6171.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=155382 first=0 last=-1 fps=78.500 done=-1.000000 timestamp=6215.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=156484 first=0 last=-1 fps=78.511 done=-1.000000 timestamp=6259.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=157586 first=0 last=-1 fps=78.534 done=-1.000000 timestamp=6303.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=158688 first=0 last=-1 fps=78.538 done=-1.000000 timestamp=6347.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=159790 first=0 last=-1 fps=78.560 done=-1.000000 timestamp=6391.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=160892 first=0 last=-1 fps=78.596 done=-1.000000 timestamp=6435.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=161994 first=0 last=-1 fps=78.647 done=-1.000000 timestamp=6479.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=163096 first=0 last=-1 fps=78.692 done=-1.000000 timestamp=6523.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=164198 first=0 last=-1 fps=78.735 done=-1.000000 timestamp=6567.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
*** Error in `/usr/bin/transcode’: munmap_chunk(): invalid pointer: 0x00007f0160da9e7a ***
transcode command:
/usr/bin/transcode --log_no_color --progress_meter 2 --progress_rate 1102 -i /dev/sr0 -x dvd -T 1,-1,1 -a 2 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
libdvdcss2 ? Look here: Captcha
