GRUB problem
I am dual booting Windows 7 with Ubuntu 11.04 but when booting I get the message
error: unknown filesystem
grub rescue>
I have managed to boot into GRUB 2 using
set prefix=(hd0,5)/boot/grub
set root=(hd0,5)
insmod normal
normal
Is there a way to fix GRUB so I don’t have to manually boot into it?
Thanks
If your above boot procedure works all the time …
First thing I’d do is set the system to run fsck on the next boot:
sudo touch /forcefsck
then reboot … use your procedure to boot … fsck will run automatically during the boot.
if that doesn’t fix things … try:
sudo update-grub
if that doesn’t fix things … see here for instructions on reinstalling GRUB from a LiveCD;
http://linuxforums.org.uk/index.php?topic=7201.0
