HELP !!!!
Can anyone help me i’ve got a HP 2133 notepad had it from new, not used for sometime now it will not accept my username and password x
If you boot from an install CD (say an Ubuntu install CD) and select “rescue” mode … you will end up in a terminal / command prompt session and you won’t need the password to get there. At this point, change the password to something you know with;
passwd
Or if you need to check what your username is, do;
cat /etc/passwd
