Hercules delux webcam. For Linux mint (SOLVED)
Hi I have a Hercules delux webcam I use. It is usb connected
I’ve been looking at the forums and this cam seems to have issues with Linux in general
Can anyone put be right on this
I’ve looked on the Hercules website but there is nothing at all about Linux.http://www.hercules.com/us/developers/
What’s the output from:
lsusb
  • sorry to have taken so long
    ron@ron-GA-78LMT-USB3 ~ $ lsusb
    Bus 002 Device 002: ID 06f8:300d Guillemot Corp.
    Bus 003 Device 002: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser
    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 010 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 011 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
FIRST run this:
lsmod | grep gspca
is anything listed ?
if not, try running:
sudo modprobe gspca_main
does the webcam now work ?
Mothing Mark
the first input did nothing
the second input did nothing
I know the second one won’t return anything in the terminal … but have you checked your camera in something like skype ?
ok just downloading it
another trivial question
i have all my Wma music files on a usb stick what is the best wat/programm for downloading them on to mint
cam works on skype thanks
I don’t understand the question ?
If they’re on a USB stick, the stick should just open a window when inserted … doesn’t it ?
And what is a “wat/programm” ?
wat prog is bad typo
re the stick no is dosn’t open at all
saying that its just opened
So you’re sorted now ?
I am Thanks
i Guess its just getting used to where everything is and can be found
Yep, there’s certainly a small learning curve involved, but Mint does a good job of minimising it :slight_smile:
Check your webcam works in skype after a reboot … if it doesn’t, we may have to manually tell the driver to load at each boot.
