installing Flash in Ubuntu 14.04 (Solved)
Just tried to use the BBC website and was prompted to install Flash Player.
I chose APT for Ubuntu 10.04+ but was told ‘This link needs to be opened with an application’.
Problem is I don’t know which application to choose, or where to find it!
Sorry if this is a stupid question. I’m now using Ubuntu on a daily basis, so I expect there’ll be a few more before we’re done!
Open a terminal and run:
sudo apt-get install flashplugin-installer
then close ALL running web browser instances, and re-open.
test flash.
Thanks Mark.
Solved again!
I like linux more and more, and look forward to getting to grips with the command-line stuff (if I ever get the time)…
(when I think about the hassles I’ve had in Windows with this kind of thing…)
You’re most welcome … Glad to hear you’re enjoying Linux :slight_smile:
And thanks for marking the topic solved.
No problem.
Solved is solved!
M
