Installing PEAK 138508AGPK DVB-T Digital TV Hybrid PCI Card
try:
sudo modprobe -r saa7134_alsa
sudo modprobe saa7134 card=78 tuner=54
sudo modprobe saa7134_alsa
(actually you can *probably skip the reloading of saa7134_alsa … ie. the last command … it seems to automatically get loaded when you load saa7134)
and do them the right way round … remove the saa7134_alsa driver first
if that doesn’t work … send the output from the attempts, and the output from:
lsmod
Have you worked out how to scan for channels in tvtime yet ? … becuase this may be futile till you know how to do that.
peter@Petes-ubuntu-pc:~$ sudo modprobe -r saa7134_alsa
[sudo] password for peter:
FATAL: Module saa7134_alsa is in use.
peter@Petes-ubuntu-pc:~$ ismod
No command ‘ismod’ found, did you mean:
Command ‘insmod’ from package ‘module-init-tools’ (main)
Command ‘lsmod’ from package ‘module-init-tools’ (main)
ismod: command not found
Afraid I have NO IDEA, I cant see anywhere that has scan or search???
Tried ismod again and got;
peter@Petes-ubuntu-pc:~$ lsmod
Module Size Used by
rfcomm 47946 0
bnep 18436 2
bluetooth 166112 10 rfcomm,bnep
binfmt_misc 17540 1
ppdev 17113 0
snd_hda_codec_via 71209 1
snd_hda_intel 33390 2
snd_hda_codec 104802 2 snd_hda_codec_via,snd_hda_intel
snd_hwdep 13668 1 snd_hda_codec
saa7134_alsa 18602 1
snd_seq_midi 13324 0
snd_rawmidi 30547 1 snd_seq_midi
iptable_filter 12810 0
snd_pcm 96755 3 snd_hda_intel,snd_hda_codec,saa7134_alsa
ip_tables 27473 1 iptable_filter
x_tables 29846 2 iptable_filter,ip_tables
snd_seq_midi_event 14899 1 snd_seq_midi
snd_seq 61896 2 snd_seq_midi,snd_seq_midi_event
nvidia 11713772 44
ir_lirc_codec 12898 0
lirc_dev 19204 1 ir_lirc_codec
saa7134 181851 1 saa7134_alsa
snd_timer 29991 2 snd_pcm,snd_seq
ir_sony_decoder 12549 0
snd_seq_device 14540 3 snd_seq_midi,snd_rawmidi,snd_seq
ir_jvc_decoder 12546 0
ir_rc6_decoder 12546 0
ir_rc5_decoder 12546 0
ir_nec_decoder 12546 0
rc_core 26963 7 ir_lirc_codec,ir_sony_decoder,saa7134,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,ir_nec_decoder
videobuf_dma_sg 19354 2 saa7134_alsa,saa7134
videobuf_core 26390 2 saa7134,videobuf_dma_sg
v4l2_common 16454 1 saa7134
videodev 93004 2 saa7134,v4l2_common
v4l2_compat_ioctl32 17083 1 videodev
edac_core 53746 0
snd 68266 16 snd_hda_codec_via,snd_hda_intel,snd_hda_codec,snd_hwdep,saa7134_alsa,snd_rawmidi,snd_pcm,snd_seq,snd_timer,snd_seq_device
k8temp 13057 0
tveeprom 21249 1 saa7134
edac_mce_amd 23709 0
sp5100_tco 13791 0
soundcore 12680 1 snd
snd_page_alloc 18529 2 snd_hda_intel,snd_pcm
i2c_piix4 13301 0
parport_pc 36962 1
asus_atk0110 18078 0
wmi 19256 0
lp 17799 0
parport 46562 3 ppdev,parport_pc,lp
usbhid 47198 0
usb_storage 57901 0
hid 95463 1 usbhid
uas 18027 0
floppy 70365 0
ahci 26002 5
libahci 26861 1 ahci
pata_atiixp 13164 0
r8169 52788 0
Just checked it out and I miss-typed it lol ismod instead of lsmod
What is the output from:
sudo rmmod saa7134_alsa
peter@Petes-ubuntu-pc:~$ sudo rmmod saa7134_alsa
ERROR: Module saa7134_alsa is in use
have you got ANY applications open that might be using the driver … ie. is tvtime still open ?
Close ALL running applications and try this again:
sudo rmmod saa7134
Nope… theres NOTHING using it because as far as I know, IT’S NOT INSTALLED!
I don’t remember installing it
Something is definitely using the saa7134_alsa driver.
Reboot … and when your system restarts do nothing other than open a terminal and run:
sudo rmmod saa7134
Nope… Didn’t work
I tried something… Removed my GRAPHICS CARD and I get this…
http://img266.imageshack.us/img266/1323/screenshotat20111130004.th.png
I have never seen the bar at the bottom and the bar ar the top is different too, when I had the grapgics card installed it was not in colour and I didn’t have ‘Places’ there either.
How do I go about uninstalling my graphics drivers?
What are you doing ? … this has nothing to do with your GFX card
Put the GFX card back in … you are being presented with the gnome-session-fallback interface.
try this and tell me what happens:
sudo rmmod -f saa7134_alsa
sudo rmmod saa7134
or just try
then if either of those work without an error … what is the output from:
tvtime
Tried sudo rmmod -f saa7134_alsa and got;
peter@Petes-ubuntu-pc:~$ sudo rmmod -f saa7134_alsa
ERROR: Removing ‘saa7134_alsa’: Resource temporarily unavailable
same on the first command.
also, in the previous screenshot, how can I get that desktop back, I preferred it as everything was organised, the activities and programs, it was easier to choose what I wanted.
Leave the TV card thing with me as i’m off to bed.
The other desktop … log off … now at the login screen, click the little cog symbol above where you enter your password, and select GNOME Classic … now login normally … that will give you the older style 2 panel desktop (as in your screenshot).
As I’m not 100% sure which desktop you’re after -
GNOME = single top panel
GNOME Classic = panel at top and bottom
Thats ok, it IS late. Nite nite :slight_smile:
Thanks for the help
And on the desktop thingy too .
If you can’t get the GNOME desktop to work … you’ll have to put your GFX card back in … it defaulted to GNOME Classic because whatever card you were using didn’t support the full GNOME desktop.
It doesnt work with the GFX card put back in either, same view
activate the driver in “Additional Drivers” … if necessary, de-activate it, then re-activate it.
