In tvtime, what have you got set as the video source ?
Setup video source Input Configuration > Change Video Source > Setup source as per your setup
Setup frequencies table
You need to setup the channels you are receiving with the tuner … try the europe frequencies table. Channel management > Change Frequency table > Select new table
Scan Channel
Finally, you need to scan for channels Channel management > Change Frequency table > Scan channels for signal > Back > Exit
did it find anything ?
You could also try running:
sudo gedit /etc/modprobe.d/saa7134.conf
and changing: options saa7134 card=78 tuner=54
to options saa7134 card=81 tuner=54
SAVE the file and REBOOT … then test again in TvTime.
I’ve been doing a bit of searching myself and found this JustLinux Forums
Don’t know if its where you got any of your info from, will any of it be any more help (if I cant get it working after trying your last suggestion?).
Tried it but still not working.
I have noticed something tho’… In Arista, when selecting a location, strangely the card showed up, in three formats. I didnt think to get a screenshot but after it has finished converting I will upload a screenshot.
I am also going to start another thread on trying to get the TV card to work with VLC so not to clutter this thread up too much.
How do I get a screenshot when theres a drop-down menu, I cant use ‘Priint-Screen’ as this doesnt work when theres a drop-down menu.
Having another bash at my TV Card. I have opened Terminal as root and I am having a bit more success.
I have found I can actually get it to scan channels now as before I was opening Terminal as normal and it was not letting me scan channels.
The only problem is that TVTime is coming up as showing No Signal but I have got it connected to my Video recorder which has my TiVo box connected to it so it is getting a signal and I am also playing a video so it will get either of the signals.
At the moment I am at a loss where to begin???
Strangely it works through VLC with these settings (See screenshot) INCLUDING AUDIO!!!
But saying that, TVTime DOES NOT RECORD so I can forget that program and use VLC to record.
What I don’t understand is I did NOTHING different to last time with either TVTime OR VLC, you can see what settings I ‘tweaked’ in VLC and ONLY them, so WHAT id different THIS TIME?
