Installing Photivo
Hi.
Recently Mark suggested I give Photivo a try for RAW file conversion. I’ts been ages since I have done a PPA so I was wondering if someone could help? Linux - Photivo
Thanks
Adam
Peppermint 4
sudo add-apt-repository ppa:dhor/myway
sudo apt-get install photivo
:wink:
Worked a treat. Thanks Mark. :slight_smile:
No problem … let me know if it’s any good, I’m not a photographer but always good to know whether to recommend something or not :slight_smile:
