Installing VLC 2.1.0 for Ubuntu Natty Narwhal or lower.
Many people running versions of Ubuntu Natty Narwhal or lower, or even people with distros based on Natty Narwhal (e.g. Peppermint 2) will find that they can’t get the latest VLC 2.1.0 update from the site. Good news is, there’s a PPA for those who happen to be on “old” versions of Ubuntu or distros based on them.
A simple tutorial, nothing fancy. Quick, easy & painless.
Terminal commands:
sudo apt-add-repository ppa:videolan/master-daily
sudo apt-get update && sudo apt-get install vlc
For a new features list see here:
http://www.addictivetips.com/windows-tips/whats-new-in-vlc-2-0-we-review-the-new-features-improvements/
Can I update my version of VLC? I am running version 1.1.12 on 11.10 Oneiric Ocelot
The PPA I’m using is;
Index of /n-muench/vlc/ubuntu oneiric main
Index of /n-muench/vlc/ubuntu oneiric main (Source Code)
is this correct?
Yeah the PPA will work for Oneiric. Although I’m positive 2.1.0 is in the repo’s. Be sure to check first. :slight_smile:
Nope, checked the Ubuntu Software Centre and its still 1.1.12.2 and in my Synaptic Package Manager it’s the same latest version as I’ve got installed.
Did you use the PPA update? If you did, open VLC then goto Help > About VLC
That will tell you the version you have INSTALLED.
Check first post with screenshot of said info.
Here try this:
sudo add-apt-repository ppa:videolan/stable-daily
It worked a treat, thanks Bks
