Internet Connection Sharing
Is there such a thing as internet connecting sharing in Linux. I am looking to share my VPN connection with my internet TV on a windows PC I would use internet connection sharing to do this.
Is their a suitable program in Linux the laptop is using mint 10.
Thanks in advance…
YES … in NetworkManager (by your clock), select the adapter that is going to be connected to the TV, and on the IPv4 tab set the “Method” to “Shared to other computers”
http://linuxforums.org.uk/MGalleryItem.php?id=1536
Also probably a good idea to set the IPv6 Method to “Ignore”
Thanks will give it a go…
Yes worked a treat, didn’t realise you could change connection settings in that way very useful.
Thanks for your help.
