Is there a better alternative to Simple Scan? SOLVED
Hi all,
At the moment I have been using Simple Scan which is fine for documents but, not good for photos as it is just too simple. Are there any programmes that I can use to edit photos?
I am running Mint 13, my printer/scanner is an old HP 750PSC. Should I upgrade Mint too?
Thanks,
Tanya
Yes … look to install Xsane
sudo apt-get install xsane
or look for it in your package manager(s) / Software Centre.
You can stay on Mint 13 if you like, it’ll still be supported for a few years yet :slight_smile:
Thank you! :smiley:
For my bit … NP :slight_smile:
