Is there an Easy way to Root an Android tablet using Linux?
Dose any one know if there is an Easy way to Root an Android tablet using Linux?
Which make/model of Android tablet ?
Make novotech model- PWS700EJ
See this page:
Now if you check out the link to the Bin4ry Root Method:
it suggests it can be done from Linux
I must add, I’ve not tested these instructions (and I’m no Android device rooting guru) … so on your head be it.
OK will check it out… thanks.
