Kingsoft Office
Hi guys can anyone tell the best place to download and install Kingsoft Office I tried following the instructions [url]herehttp://www.noobslab.com/2013/05/microsoft-office-alternative-kingsoft.htm [/url
cd && wget -O kingsoft-office-NoobsLab.deb http://goo.gl/HplIfc
sudo dpkg -i kingsoft-office-NoobsLab.deb
rm kingsoft-office-NoobsLab.deb
but on the 2nd command it failed with “couldn’t find package”
Many thanks
2 seconds
Download this file:
http://wdl.cache.ijinshan.com/wps/download/Linux/unstable/kingsoft-office_9.1.0.4244~a12p3_i386.deb
and double click to install.
A while ago when you first started Kingsoft Writer after install it mentioned something about missing fonts … if it still does that, let me know and I’ll tell you how to fix it.
Ignore these links, I’m just putting them here for future reference:
http://wps-community.org/download.html
http://peppermintos.net/viewtopic.php?p=40107#p40107
Don’t know what’s gong on but that’s a painfully slow download it’s saying about 10 hours :frowning:
It’s coming all the way from China … on a rickshaw :slight_smile:
Well it looks like the rickshaw has come to a halt hasn’t shifted in the last five minutes :slight_smile:
Mine says about 10 mins … so try stopping the download and restarting.
if it’s still stupidly slow I’ll up it to my dropbox, but that’ll be slow too … uploads to dropbox are painfully slow
Download failed with “Network Timeout”
This might be an issue with the netbook I started the download on my PC and I’m getting 1 to 2 hours but at least it’s downloading but it won’t even start downloading on the netbook :frowning:
EDIT
It downloaded it in minutes from the first site I tried and I know now why it didn’t work with the second command, I could try it again if you think it’s the right version ?
it’s unlikely to be the latest version
Try stopping the download from kingsoft and starting it again … mine’s already finished … I’m upping it to dropbox now though just in case
I did try again and it’s just failed :frowning:
Gimme a coupla mins … for some reason uploading to dropbox seems immensely quick today :slight_smile:
I changed the DNS settings and it’s now downloading it’s saying about 20 minutes
I take it back … it’s slowed down.
Try this…
go here:
and click on the link called
took about ten mins to download for me.
Ahh yes, the famous Virgin DNS/cache doodad
I’m nearly there it speeds up and slows down I’m at 100mb downloaded so not much to go starting another download might slow it down
Ok I got it installing now :slight_smile:
Is there any merit in swapping one closed source Office Suite for another, specially as it does not appear to be supporting ODF. ???
Hi SeZo
I agree I don’t like the fact it’s proprietary either but if it keeps my daughter out of Windows it might be worth it :slight_smile:
@ SeZo
Other than it supports M$ docx/xlsx/pptx better than LibreOffice … NO
But the overriding factor here (for Emegra’s daughter) is M$ Office compatibility.
Personally I have both installed.
Ok i’m getting the font warnings you were talking about in Writer and some symbol warnings in Spreadsheet
