Lifelines (SOLVED)
Hi guys
I’ve just installed lifelines (a genealogy program) which seemed to install ok but I can’t find it in the menu nor can I get it to open from the terminal I’ve tried lifelines, Lifelines & LifeLines each time I get “no file or directory” also I’ve checked the filesystem and I can’t see any reference to it in /bin or /usr/bin, I’ve un-installed and re-installed but still no luck
any help would be much appreciated
You could search for it:
sudo updatedb
locate life
Try different variations on life
Thanks SeZo
Still can’t run Lifelines but here’s the output
graeme@Linux1 ~ $ sudo updatedb
[sudo] password for graeme:
graeme@Linux1 ~ $ locate lifelines
/usr/lib/lifelines
/usr/lib/lifelines/llines
/usr/share/doc/lifelines
/usr/share/doc/lifelines/.linesrc.gz
/usr/share/doc/lifelines/ABOUT-NLS.gz
/usr/share/doc/lifelines/AUTHORS
/usr/share/doc/lifelines/NEWS.gz
/usr/share/doc/lifelines/README
/usr/share/doc/lifelines/README.AUTOCONF.gz
/usr/share/doc/lifelines/README.DEVELOPERS.gz
/usr/share/doc/lifelines/README.Debian
/usr/share/doc/lifelines/README.INTERNATIONAL
/usr/share/doc/lifelines/README.LAYOUT
/usr/share/doc/lifelines/README.MAINTAINERS
/usr/share/doc/lifelines/README.MAINTAINERS.rpm
/usr/share/doc/lifelines/README.MAINTAINERS.win32
/usr/share/doc/lifelines/changelog.Debian.gz
/usr/share/doc/lifelines/copyright
/usr/share/doc/lifelines/examples
/usr/share/doc/lifelines/lines.cfg.gz
/usr/share/doc/lifelines/lines.cfg.input.gz
/usr/share/doc/lifelines/ll-devguide.html
/usr/share/doc/lifelines/ll-devguide.xml.gz
/usr/share/doc/lifelines/ll-reportmanual.xml.gz
/usr/share/doc/lifelines/ll-userguide.xml.gz
/usr/share/doc/lifelines/examples/linesrc.gz
/usr/share/locale/da/LC_MESSAGES/lifelines.mo
/usr/share/locale/de/LC_MESSAGES/lifelines.mo
/usr/share/locale/el/LC_MESSAGES/lifelines.mo
/usr/share/locale/eo/LC_MESSAGES/lifelines.mo
/usr/share/locale/es/LC_MESSAGES/lifelines.mo
/usr/share/locale/fr/LC_MESSAGES/lifelines.mo
/usr/share/locale/it/LC_MESSAGES/lifelines.mo
/usr/share/locale/nl/LC_MESSAGES/lifelines.mo
/usr/share/locale/pl/LC_MESSAGES/lifelines.mo
/usr/share/locale/rw/LC_MESSAGES/lifelines.mo
/usr/share/locale/sv/LC_MESSAGES/lifelines.mo
/usr/share/menu/lifelines
/usr/share/pixmaps/lifelines.xpm
/var/cache/apt/archives/lifelines-reports_3.0.61-2_all.deb
/var/cache/apt/archives/lifelines_3.0.61-2_amd64.deb
/var/cache/apt/archives/lifelines_3.0.61-2_i386.deb
/var/lib/dpkg/info/lifelines.list
/var/lib/dpkg/info/lifelines.md5sums
/var/lib/dpkg/info/lifelines.postinst
/var/lib/dpkg/info/lifelines.postrm
graeme@Linux1 ~ $ lifelines
lifelines: command not found
graeme@Linux1 ~ $
Many thanks
Have you tried to run in Terminal:
llines
According this that is the command to start with GUI interface
No I haven’t but having read your link that’s clearly what I’m doing wrong, I’m not at that PC right now but I’ll try that when I get home and post back
Many thanks
Yeah you got it SeZo
llines opens it up
I don’t know how you found that page I searched and couldn’t find anything relevant
must try harder :slight_smile:
Many thanks
No probs, glad to be of help. :slight_smile:
Your locate results given me the clue.
