Linux installed on a USB, what now?
Hmm … this may be a problem, or it may not … depends if we need to install anything.
Can you open a terminal and run this command:
dpkg -l | grep modeswitch
and post the output.
lsusb
and tell us the make/model of dongle.
Internet connection sorted. Looked at Hints and Tips.
Thank you to everybody who helped.
Parrotslive
Okey dokey … you seem to be doing fine on your own :slight_smile:
