Looking for a TV card
I am looking for a new TV card compatible with Linux. I’ve installed Ubuntu Studio, dual booting with Kubuntu.
I only need one around £50, internal, one TV input standard co-ax.
Does anyone know where I can get one from a UK supplier? NOT Ebay or Amazon.
Thanks
I haven’t had a TV card since pre-digital … so I’m afraid any info I might have would be a little dated :wink:
What kind of slot? PCI, PCI-E, something else…?
If you’re not sure, let us know what CPU the machine has, the expansion slot can probably be worked out from that.
My details are in my sig at the bottom. It’s an ASUS M5A78LM-USB3 MoBo
M5A78L-M/USB3
Expansion Slots
1 x PCIe x16
1 x PCIe x1
2 x PCI
So I guess the next question must be which slots are unoccupied ?
(kinda pointless getting an internal card if there’s nowhere to put it)
They’re all empty…
According to one of the comments, this:
http://www.amazon.co.uk/Hauppauge-WinTV-Nova-digital-tuner/dp/B000I1RHWA
is on the MythTV compatibility list and the commenter said it worked perfectly for him
in fact there are a couple of comments that suggest it works well in Linux
And from a non-Amazon site - http://www.ebuyer.com/255035-hauppauge-wintv-nova-t-500-dual-tuner-low-profile-pci-card-00289
The dual tuner one looks good as we have 2 VM TiVo boxes and I’m more tempted to buy it from Ebay as I have some free next day delivery tokens…
Might buy it later this month (a birthday prezzie for myself lol) or maybe next month…
Hang on… I’ve just had another look at the one MARK posted and it says DUAL but only shows a ONE input TV card!!!
