loss of menu choices
I have happily used Peppermint 6 on my 4 Acer Aspire one’s all of this year.
I have encountered a small problem on one of them recently and am sue that it is something stupid
that I have done.
The menu on the left hand side when I startup has now been reduced to the following :
Chromium
Software Manager
Terminal
Search
File Manager
Run
Logout
Please could someone help me get all the other choices back.
Many thanks,
Kevin Woodward
Can you open a terminal (Ctrl+Alt+T) and post the output from this command
ls -a ~/.config/menus
Thanks for your reply.
Tried that but getting error message
cannot access /home/kevin/.config/menus: no such file
Okay, try this … open a terminal and run:
mv ~/.cache/menus ~/.cache/menus-old
lxpanelctl restart
now log off/on (or reboot)
does the menu work now ?
Thanks for trying to help but that did not work.
Maybe I should just re-install Peppermint 6 - but then I would lose my files etc
Do the menus work if you log into a guest session ?
if so, we could create a new user … add it to the right groups … copy across your docs/pics/etc … then delete the old account
