lost screen (Solved)
Hi,
I usually have an option to switch between 1 screen and 2 screen but I only have 1 screen now. Where has the other screen gone ?
I must have deleted it ? help please
Don W
Do you mean “Screens” (as in monitors), or “Workspaces” (as in the workspace switcher on the bottom panel) ?
Workspaces I think, Mark.
Okay, in the main menu go to:-
menu > Preferences > Peppermint Control Center
Select the “Window Manager” tab
and set
Number of workspaces: 2
Did that change the number of available workspaces on the bottom panel ? … or are you saying the workspace switcher no longer exists at all on the bottom panel ?
If the workspace switcher is missing altogether…
Right-click on a blank space on the bottom panel, and select:-
Panel > Panel Preferences
then select the “Items” tab
Check if there’s already a “Workspace Switcher” item.
If not, click the “Add (+)” button … highlight the “Workspace Switcher” item, and click the “+ Add” button you should see a workspace switcher appear on the bottom panel) … then click the “Close” button.
Back in the Panel Preferences window, highlight the “Workspace Switcher” item and use the UP/DOWN arrow buttons to move it to where you want it on the bottom panel.
(default is just above the “Notification Area” item)
Thanks Mark,
Window Manager > workspaces 2 was already set, so I went to Panel Preferences>Items and entered it below the Notification Area (I like these switches on the right hand side).
All is now well and I think I could have done this if I had looked back some of the threads that have been raised on this forum ?? Maybe not as I am a bit of a numpty
take care
Don W
No problem Don :slight_smile:
