Lucid desktop Upload issue
Hi guys i have a maverick server and i installed a copy of Lucids web desktop. Seems im having an issue when trying to upload any thing.
What i have tried: I changed the size of the file upload allowed in Php.ini this didnt seem to help.
the error states: Error undefined
any help is much appreciated.
little further information:
It does let me modify existing documents on the desktop and save them.
Seems that it will allow me to install themes, which is weered because part of the install process is uploading the file form my home machine.
There seems to be a distinct lack of documentation for the Lucid web desktop… all I can find is a suggestion to:
open your browser's javascript debug console and see if there are any error messages either there or in your PHP error logs when you upload a file, that may lead to some insight as to what's going on.
http://www.lucid-desktop.org/forum/threads/id/35/#snap_post219
not giving any clues after trying that.
Where could i locate the php error log.
See if there is anything useful in the apache2 error.log /var/log/apache2/error.log
From what I gather…
By default ALL apache errors should be logged to /var/log/apache2/error.log… but if you want to set up a log file for “just” php errors, you’ll have to uncomment and edit the line:
;error_log = php_errors.log
in your:
/etc/php5/apache2/php.ini
file, to reflect the path/filename of where you want the log file to go.
then you’ll have to restart apache:
sudo /usr/sbin/apache2ctl restart
Be sure to back up your original /etc/php5/apache2/php.ini first though, just in case.
http://www.php.net/manual/en/ini.list.php
well seems i was using an unstable version (1.0.1) and now have it worknig using version 1.0.0 Thanks mark for all the help with this one.
