@ Sezo
I’m currently looking at this:
Mint 14 is based on 12.10 right ?
and Mint doesn’t update the kernel like Ubuntu ?
@ Toonman
@ Sezo
@ Toonman
uname -a
Linux adammaureen-EQUIUM-L350 3.5.0-17-generic #28-Ubuntu SMP Tue Oct 9 19:32:08 UTC 2012 i686 i686 i686 GNU/Linux
. 12.04
output
uname -a
Was it Ubuntu 12.04 where it worked ? … or 12.10 ?
and what’s the make/model/Android version of the phone ?
Yes Mint 14 is based on 12.10
and Mint doesn't update the kernel like Ubuntu ?
and comes with kernel 3.5. Although not used it for a while, but as I remember it the kernel updates are the same as in Ubuntu
but not offered unless you set the preferences to 5 in the update manager.
Sorry. I am on call with work tonight. I will have to come back tomorrow.
Thanks Guys.
as I remember it the kernel updates are the same as in Ubuntu but not offered unless you set the preferences to 5 in the update manager.
That’s what I meant
According to that bug report, the bug appeared in kernel 3.3, and was fixed in 3.5.0-19 … so I reckon just enabling the kernel updates, or running:
then:
sudo apt-get upgrade
should bring in a later kernel.
If you see any messages about the kernel being “held back” … run:
sudo apt-get dist-upgrade
Then reboot, and see which kernel you’re now on with:
uname -a
Then check if you’re still getting those errors in dmesg, and if things are working now.
dmesg | tail -n 40
[ 19.002755] init: plymouth-stop pre-start process (1559) terminated with status 1
[ 24.245550] wlan0: authenticate with 90:c1:15:76:7e:fa
[ 24.254752] wlan0: direct probe to 90:c1:15:76:7e:fa (try 1/3)
[ 24.456076] wlan0: send auth to 90:c1:15:76:7e:fa (try 2/3)
[ 24.461384] wlan0: authenticated
[ 24.468061] wlan0: associate with 90:c1:15:76:7e:fa (try 1/3)
[ 24.471527] wlan0: RX AssocResp from 90:c1:15:76:7e:fa (capab=0x431 status=0 aid=1)
[ 24.472295] wlan0: associated
[ 24.472752] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 27.020788] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 102.652082] usb 2-3: >new high-speed USB device number 4 using ehci_hcd
[ 102.785085] usb 2-3: >Dual-Role OTG device on non-HNP port
[ 102.785206] usb 2-3: >can’t set HNP mode: -32
[ 102.900082] usb 2-3: >new high-speed USB device number 5 using ehci_hcd
[ 103.032962] usb 2-3: >Dual-Role OTG device on non-HNP port
[ 103.033082] usb 2-3: >can’t set HNP mode: -32
[ 103.148077] usb 2-3: >new high-speed USB device number 6 using ehci_hcd
[ 103.169132] usb 2-3: >Dual-Role OTG device on non-HNP port
[ 103.169263] usb 2-3: >can’t set HNP mode: -32
[ 103.284081] usb 2-3: >new high-speed USB device number 7 using ehci_hcd
[ 103.305073] usb 2-3: >Dual-Role OTG device on non-HNP port
[ 103.305197] usb 2-3: >can’t set HNP mode: -32
[ 103.308080] hub 2-0:1.0: >unable to enumerate USB device on port 3
[ 103.576081] usb 6-1: >new full-speed USB device number 2 using uhci_hcd
[ 103.714923] usb 6-1: >not running at top speed; connect to a high speed hub
[ 103.739912] usb 6-1: >Dual-Role OTG device on non-HNP port
[ 103.741913] usb 6-1: >can’t set HNP mode: -32
[ 103.852091] usb 6-1: >new full-speed USB device number 3 using uhci_hcd
[ 103.990787] usb 6-1: >not running at top speed; connect to a high speed hub
[ 104.013777] usb 6-1: >Dual-Role OTG device on non-HNP port
[ 104.015774] usb 6-1: >can’t set HNP mode: -32
[ 104.128057] usb 6-1: >new full-speed USB device number 4 using uhci_hcd
[ 104.158704] usb 6-1: >not running at top speed; connect to a high speed hub
[ 104.183688] usb 6-1: >Dual-Role OTG device on non-HNP port
[ 104.185692] usb 6-1: >can’t set HNP mode: -32
[ 104.296082] usb 6-1: >new full-speed USB device number 5 using uhci_hcd
[ 104.326618] usb 6-1: >not running at top speed; connect to a high speed hub
[ 104.351606] usb 6-1: >Dual-Role OTG device on non-HNP port
[ 104.353605] usb 6-1: >can’t set HNP mode: -32
[ 104.354608] hub 6-0:1.0: >unable to enumerate USB device on port 1
It still is not working.
Mobile phone is Sony Experia Arc s Andriod 4.0
Well that doesn’t appear to have updated the kernel at all … do you know how to set the mint updater to accept kernel updates ?
If so, try making level 5 updates visible and see if there’s a kernel update.
If there isn’t, we’ll manually install kernel 3.6
Sorry, I dont know how to set the Kernel updates.
Shall we just try manually installing the 3.6 kernel ?
If so, run these commands in sequence:
mkdir ~/Desktop/kernel3.6
cd ~/Desktop/kernel3.6
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.6-quantal/linux-headers-3.6.0-030600-generic_3.6.0-030600.201209302035_i386.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.6-quantal/linux-headers-3.6.0-030600_3.6.0-030600.201209302035_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.6-quantal/linux-image-3.6.0-030600-generic_3.6.0-030600.201209302035_i386.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.6-quantal/linux-image-extra-3.6.0-030600-generic_3.6.0-030600.201209302035_i386.deb
sudo dpkg -i *.deb
When that command finishes … REBOOT … then send the output from:
uname -a
then unplug the phone (if plugged in), replug the phone, then send the output from:
dmesg | tail -n 25
Thanks. Give me a couple of days. Been called away again.
If my memory serves me correct, for me to mount my SGS3 / N7 in Ubuntu/Mint I had enable mass storage via USB settings on the phone / tablet, or enable UMS mode. Having had enough of the issues, I said f*** it, and just installed Samba on my Android devices. Much simpler, and easier.
Samba for Android - Google Play Store
Though it’s not “THE” solution you’re looking for, it is “a” solution.
Sorry for the lengthy delay. I have been working away.
Output
uname -a
Linux adammaureen-EQUIUM-L350 3.6.0-030600-generic #201209302035 SMP Mon Oct 1 00:43:10 UTC 2012 i686 i686 i686 GNU/Linux
Output when phone plugged back ijn.
dmesg | tail -n 25
[ 2093.385048] usb 2-3: can’t set HNP mode: -32
[ 2093.500057] usb 2-3: new high-speed USB device number 7 using ehci_hcd
[ 2093.521049] usb 2-3: Dual-Role OTG device on non-HNP port
[ 2093.521165] usb 2-3: can’t set HNP mode: -32
[ 2093.636060] usb 2-3: new high-speed USB device number 8 using ehci_hcd
[ 2093.657049] usb 2-3: Dual-Role OTG device on non-HNP port
[ 2093.657169] usb 2-3: can’t set HNP mode: -32
[ 2093.660064] hub 2-0:1.0: unable to enumerate USB device on port 3
[ 2093.928073] usb 6-1: new full-speed USB device number 2 using uhci_hcd
[ 2094.071080] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.098081] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.100093] usb 6-1: can’t set HNP mode: -32
[ 2094.212061] usb 6-1: new full-speed USB device number 3 using uhci_hcd
[ 2094.355079] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.380080] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.382075] usb 6-1: can’t set HNP mode: -32
[ 2094.492072] usb 6-1: new full-speed USB device number 4 using uhci_hcd
[ 2094.523077] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.550080] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.552092] usb 6-1: can’t set HNP mode: -32
[ 2094.664068] usb 6-1: new full-speed USB device number 5 using uhci_hcd
[ 2094.694079] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.721078] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.723076] usb 6-1: can’t set HNP mode: -32
[ 2094.724083] hub 6-0:1.0: unable to enumerate USB device on port 1
I’ve asked this multiple times and you haven’t answered yet … Which version of Ubuntu did it work in ?
My apologies I thought I had.
UBUNTU 12.10 Also The Andriod operating system is 2.3 NOT 4.1 as I said in a previous post.
Thanks
Is this the SAME PC that it previously worked on ?
Seems odd that it would work on Ubuntu 12.10 but not Mint 14 as they use the same kernel series and the same(ish) repos … so I’m trying to figure out if anything else has changed ?
Yes it’s the same PC. Even more odd is the fact that I have now plugged in my Samsung Galaxy note 2 and it is instantly recognized. There have been no problems until the last week or so. No Andriod updates and as far as I know None for Mint. Now here is the really interesting news…it works with my netbook with Peppermint 3!
Just for comparison, can you plug it into the Peppermint 3 netbook, then send the output from:
dmesg | tail -n 30
This is in media transfer mode NOT USB network sharing
[ 1087.856919] usb 5-1: can’t set HNP mode: -32
[ 1087.968144] usb 5-1: new full-speed USB device number 19 using uhci_hcd
[ 1088.111060] usb 5-1: not running at top speed; connect to a high speed hub
[ 1088.134075] usb 5-1: Dual-Role OTG device on non-HNP port
[ 1088.136107] usb 5-1: can’t set HNP mode: -32
[ 1088.248076] usb 5-1: new full-speed USB device number 20 using uhci_hcd
[ 1088.279149] usb 5-1: not running at top speed; connect to a high speed hub
[ 1088.305149] usb 5-1: Dual-Role OTG device on non-HNP port
[ 1088.307141] usb 5-1: can’t set HNP mode: -32
[ 1088.476139] usb 5-1: new full-speed USB device number 21 using uhci_hcd
[ 1088.506262] usb 5-1: not running at top speed; connect to a high speed hub
[ 1088.533264] usb 5-1: Dual-Role OTG device on non-HNP port
[ 1088.535258] usb 5-1: can’t set HNP mode: -32
[ 1088.536280] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1145.768129] usb 2-2: new high-speed USB device number 21 using ehci_hcd
[ 1145.901320] usb 2-2: New USB device found, idVendor=04e8, idProduct=6860
[ 1145.901332] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1145.901340] usb 2-2: Product: SAMSUNG_Android
[ 1145.901347] usb 2-2: Manufacturer: SAMSUNG
[ 1145.901353] usb 2-2: SerialNumber: 4df735d23b4acfa5
[ 1145.902754] cdc_acm 2-2:1.1: This device cannot do calls on its own. It is not a modem.
[ 1145.902920] cdc_acm 2-2:1.1: ttyACM0: USB ACM device
[ 1401.361346] usb 2-2: USB disconnect, device number 21
[ 1401.696110] usb 2-2: new high-speed USB device number 22 using ehci_hcd
[ 1401.829270] usb 2-2: New USB device found, idVendor=04e8, idProduct=6864
[ 1401.829282] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1401.829289] usb 2-2: Product: SAMSUNG_Android
[ 1401.829296] usb 2-2: Manufacturer: SAMSUNG
[ 1401.829303] usb 2-2: SerialNumber: 4df735d23b4acfa5
[ 1401.832412] rndis_host 2-2:1.0: usb0: register ‘rndis_host’ at usb-0000:00:1d.7-2, RNDIS device, 02:00:61:37:62:30
