Mint 17 mate 64bit update manager issues (Resolved)
I get the following error messages when running update manager is this a problem that needs action?
Ignoring file ‘getdeb.list.bck’ in directory ‘/etc/apt/sources.list.d/’ as it has an invalid filename extensionFailed to fetch http://archive.getdeb.net/ubuntu/dists/qiana-getdeb/apps/binary-amd64/Packages 404 Not Found [IP: 104.28.25.125 80]
Failed to fetch http://archive.getdeb.net/ubuntu/dists/qiana-getdeb/apps/binary-i386/Packages 404 Not Found [IP: 104.28.25.125 80]
Some index files failed to download. They have been ignored, or old ones used instead.
I am still receiving updates.
Thanks in advance.
You can get rid of the first error by removing the offending file:
sudo rm /etc/apt/sources.list.d/getdeb.list.bck
For the others it appears that the /qiana-getdeb distribution no longer exists.
Have a look here:http://archive.getdeb.net/ubuntu/dists/
What’s the output from:
inxi -r
I’m pretty sure those getdeb entries should read “trusty” not “qiana” … I don’t think getdeb have ever followed the mint naming convention have they ?
userone@Office2 ~ $ inxi -r
Repos: Active apt sources in file: /etc/apt/sources.list
deb http://download.ebz.epson.net/dsc/op/stable/debian/ lsb3.2 main
Active apt sources in file: /etc/apt/sources.list.d/additional-repositories.list
deb http://quozl.netrek.org/pptp/pptpconfig ./
Active apt sources in file: /etc/apt/sources.list.d/atareao-atareao-trusty.list
deb Index of /atareao/atareao/ubuntu trusty main
deb-src Index of /atareao/atareao/ubuntu trusty main
Active apt sources in file: /etc/apt/sources.list.d/docky-core-stable-trusty.list
deb Index of /docky-core/stable/ubuntu trusty main
deb-src Index of /docky-core/stable/ubuntu trusty main
Active apt sources in file: /etc/apt/sources.list.d/getdeb.list
deb Ubuntu - GetDeb qiana-getdeb apps
Active apt sources in file: /etc/apt/sources.list.d/jitsi.list
deb http://download.jitsi.org/deb unstable/
Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
deb http://linux-mint.froonix.org qiana main upstream import
deb http://extra.linuxmint.com qiana main
deb Index of /ftp/ubuntu trusty main restricted universe multiverse
deb Index of /ftp/ubuntu trusty-updates main restricted universe multiverse
deb Index of /ubuntu trusty-security main restricted universe multiverse
deb Index of /ubuntu trusty partner
Active apt sources in file: /etc/apt/sources.list.d/official-source-repositories.list
deb-src http://linux-mint.froonix.org qiana main upstream import
deb-src http://extra.linuxmint.com qiana main
deb-src Index of /ftp/ubuntu trusty main restricted universe multiverse
deb-src Index of /ftp/ubuntu trusty-updates main restricted universe multiverse
deb-src Index of /ubuntu trusty-security main restricted universe multiverse
deb-src Index of /ubuntu trusty partner
userone@Office2 ~ $
run:
sudo gedit /etc/apt/sources.list.d/getdeb.list
and change any mention fo “qiana” to “trusty
so
deb http://archive.getdeb.net/ubuntu qiana-getdeb apps
becomes
deb http://archive.getdeb.net/ubuntu trusty-getdeb apps
SAVE the file and exit gedit
now run:
and if there are any errors post them back here
userone@Office2 ~ $ sudo gedit /etc/apt/sources.list.d/getdeb.list
[sudo] password for userone:
sudo: gedit: command not found
userone@Office2 ~ $
OK I sorted this myself “gedit” is a text editor and in mint 17 mate the text editor is pluma so changed them over.
Update completed with no issues.
try
sudo pluma /etc/apt/sources.list.d/getdeb.list
Resolved.
Thanks.
You’re welcome :slight_smile:
