Mount problems
I’ve created a new partition on a 4TbHd (see PREVIOUS thread) and now, after editing the fstab I am getting errors;
When I try and open EXT-01
An error occurred while accessing ‘Home’, the system responded: The requested operation has failed: Error mounting system-managed device /dev/sdk1: Command-line `mount “/media/EXT-03”’ exited with non-zero exit status 32: [mntent]: warning: no final newline at the end of /etc/fstab mount: wrong fs type, bad option, bad superblock on /dev/sdk1, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so
When I try and open EXT-03
An error occurred while accessing ‘Home’, the system responded: The requested operation has failed: Error mounting system-managed device /dev/sdi1: Command-line `mount “/media/EXT-02”’ exited with non-zero exit status 12: [mntent]: warning: no final newline at the end of /etc/fstab NTFS signature is missing. Failed to mount ‘/dev/sdi1’: Invalid argument The device ‘/dev/sdi1’ doesn’t seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
sudo blkid
/dev/sda1: UUID=“a4cc9e70-36d1-4dcd-ad90-ec5c2aaf4b51” TYPE=“ext4”
/dev/sda2: UUID=“718377f7-8759-44ad-888d-e0fb3f91c5e4” TYPE=“swap”
/dev/sda5: UUID=“b670b54e-542b-43fe-9329-f620887acaa1” TYPE=“ext4”
/dev/sda6: LABEL=“Drive5” UUID=“127a7d9d-be7b-4ec8-9a05-661dd763d9e6” TYPE=“ext4”
/dev/sdb1: LABEL=“Drive1” UUID=“d5e1db61-b980-4624-801c-e0546b288b8f” TYPE=“ext4”
/dev/sdc1: LABEL=“Drive3” UUID=“3211899a-4095-4d76-8d34-70c534d52374” TYPE=“ext4”
/dev/sdi1: LABEL=“EXT-03” UUID=“70364fca-b0a2-4058-a976-1bd435e101a5” TYPE=“ext4”
/dev/sdj1: LABEL=“EXT-02” UUID=“3E9E5F1B0F3E4B8D” TYPE=“ntfs”
/dev/sdk1: LABEL=“EXT-01” UUID=“9472C6BD72C6A37A” TYPE=“ntfs”
sudo kate /etc/fstab
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda1 during installation
UUID=a4cc9e70-36d1-4dcd-ad90-ec5c2aaf4b51 / ext4 errors=remount-ro 0 1
swap was on /dev/sda2 during installation
UUID=718377f7-8759-44ad-888d-e0fb3f91c5e4 none swap sw 0 0
/dev/sdb1 /media/Drive1 ext4 rw,user,exec 0 0
UUID=d5e1db61-b980-4624-801c-e0546b288b8f ext4 rw,user,exec 0 0
/dev/sdc1 /media/Drive3 ext4 rw,user,exec 0 0
UUID=3211899a-4095-4d76-8d34-70c534d52374 ext4 rw,user,exec 0 0
/dev/sda6 /media/Drive5 ext4 rw,user,exec 0 0
UUID=127a7d9d-be7b-4ec8-9a05-661dd763d9e6 ext4 rw,user,exec 0 0
4TbHd
/dev/sdk1 /media/EXT-03 ext4 rw,user,exec 0 0
UUID=70364fca-b0a2-4058-a976-1bd435e101a5 ext4 rw,user,exec 0 0
3TbHd X 2
/dev/sdj1 /media/EXT-01 ntfs-3g defaults,user,locale=en_GB.utf8 0 0
/dev/sdi1 /media/EXT-02 ntfs-3g defaults,user,locale=en_GB.utf8 0 0
/dev/sdi1: LABEL=“EXT-02” UUID=“3E9E5F1B0F3E4B8D” TYPE=“ntfs”
/dev/sdj1: LABEL=“EXT-01” UUID=“9472C6BD72C6A37A” TYPE=“ntfs”
/dev/sdd1 /media/Drive4 ext4 rw,user,exec 0 0
/dev/sdc /media/Win-Storage ntfs-3g defaults,user,locale=en_GB.utf8 0 0
/dev/sdk1: LABEL=“EXT-03” UUID=“70364fca-b0a2-4058-a976-1bd435e101a5” TYPE=“ext4”
That doesn’t look like you have a /home partition - is that right? It’s not compulsory to have one (it’ll be mounted under /), but it’s a standard to have one (especially when you can spare the space). Do you use LVM or RAID at all?
The important part comes afer the “Also…” below…
According to blkid /dev/sdk1 is labeled EXT-01 … so why are you trying to mount it at /media/EXT-03 ?
According to blkid /dev/sdi1 is labeled EXT-03 … so why are you trying to mount it at /media/EXT-02 ?
According to blkid /dev/sdj1 is labeled EXT-02 … yet is being mount at /media/EXT-01 ?
any reason you’re mounting them somewhere at odds with their labels ? … there’s nothing to stop you doing this, I’m just wondering ?
[b]ALSO…
according to blkid, /dev/sdi1 is formatted EXT4, yet you’re trying to mount it as NTFS (via ntfs-3g) in fstab
according to blkid, /dev/sdk1 is formatted NTFS, yet you’re trying to mount it as EXT4 in fstab[/b]
That was a cock-up on my part - wrote the wrong drive letter.
Think it’s sorted now;
sudo blkid
4TbHd
/dev/sdi1 /media/EXT-03 ext4 rw,user,exec 0 0
3TbHd X 2
/dev/sdk1 /media/EXT-01 ntfs-3g defaults,user,locale=en_GB.utf8 0 0
/dev/sdj1 /media/EXT-02 ntfs-3g defaults,user,locale=en_GB.utf8 0 0
You’re welcome.
Thanks for pointing it out Mark, it usually is something so simple that it can be missed.
