My Weather indicator (Resolved)
Hi I am using Linux mint 17.3 64bit with a mate desktop.
I have been using this desktop weather app for some years with no problems.
From about a week ago it fails to start when I log in… the setting are set to start when I log in.
I have tried uninstalling and and reinstalling but the problem remains.
I have also tried starting the program manually which often requires me to launch the program 5 or 6 times before the program starts.
I’m at a loss to see what the problem is… any help please.
What happens if you start it from the terminal ?
Seems to work OK from a terminal.
Maybe try autostarting it with a 10 second delay:
bash -c "sleep 10 ; <command to start app>"
Tried this and started OK today will see what happens for a few days before posting as resolved.
Thanks.
Okey dokey :slight_smile:
