NEED HELP INSTALLING PLAYER AND STAGE ON UBUNTU 12.04 64-bit
Hello all,
I am relatively new to this site and got referred by a family member using Linux.
Linux is very new to me. I have been using Windows for way too long. Which means I am very unfamilar with alot of Linux guestures and navigating around using the terminal and such. (Fine on the GUI)
I recently attempted to install the programs: Player, and Stage to my Ubuntu and came across many errors.
I used this site: How to install player/stage on ubuntu 12.04 LTS 32bit (Player 3.0.2 & Stage 3.2.2) - 郭璐_Kevin - 博客园
In order to help me install the above software.
I documented the errors as I was going along the installation and am seeking help!
Terminal code with errors:
I am not too great with terminology or Linux in general, but I hope you guys can help!
Thanks
Hi Mally, and welcome to the forum :slight_smile:
First try sort out the dependencies …
The following packages have unmet dependencies. libopencv-calib3d-dev : Depends: [b]libopencv-features2d-dev[/b] (= 2.3.1-7) [b]but it is not going to be installed[/b] E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
So try installing libopencv-features2d-dev:
sudo apt-get install libopencv-features2d-dev
The try your:
sudo apt-get install libgnomecanvas2-0 libgnomecanvas2-dev libgsl0-dev libgtk2.0-dev libjpeg62-dev libtool libxmu-dev swig
command again.
Do you get any errors from that command ?
Sadly, No luck.
libopencv-features2d-dev is already the newest version.
 libopencv-calib3d-dev : Depends: libopencv-features2d-dev (= 2.3.1-7) but it is not going to be installed
Same error.
Try
sudo apt-get remove --purge libopencv-calib3d-dev
sudo apt-get remove --purge libopencv-features2d-dev
sudo apt-get autoremove
sudo apt-get clean
sudo apt-get install libopencv-calib3d-dev
Thanks alot! That worked like a dream.
Following on from the tutorial, I attempted placing these commands into the terminal with my interpretation of them:
# Checking Player installations
# Should get something like: -L/usr/local/lib -lplayercore -lpthread -lltdl -ldl -lplayerinterface -lplayercommon
pkg-config --libs playercore
# Need to set dynamic library path, and others..
# Better append these into ~/.bashrc file, e.g.:
# LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
# export LD_LIBRARY_PATH
# Then:
# source ~/.bashrc
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
# Print dynamic library path, should get something like: /usr/local/lib:
echo $LD_LIBRARY_PATH
# Checking Player version
pkg-config --modversion playercore
pkg-config --modversion playerc++
This is what I input into the terminal with errors:
Still unfamiliar with Linux…
I’m a bit confused as to the order you’re doing things …
but …
I’m currently not at an Ubuntu 64bit PC, but if you come back tomorrow I’ll attempt to install them in a VM and if successful I’ll type up instructions.
Don’t get discouraged, what you’re attempting (compiling from source) is considered fairly advanced, and is rarely necessary as there’s normally a pre-compiled package somewhere … it just happens that the applications you’re trying to install have a PPA, but it hasn’t been updated with packages for 12.04, leaving you no alternative but to compile from source :frowning:
I’ll get back to you tomorrow … hopefully with a step by step walkthrough :wink:
Sorry the confusion.
It would be a great help for you to do so.
I await those instructions tomorrow, if you succeed!
Thanks alot!
Sorry it took me an extra day, but yesterday was a bit manic round here :wink:
OK, it seems that the instructions you’re following are slightly wrong for 64bit … they tell you to export the wrong path (for 64bit) … it should have been:
export PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
Here’s the FULL instructions for 12.04 64bit (and 11.10 64bit)
sudo apt-get upgrade
If you’re running Ubuntu 12.04 64bit install these dependencies:
sudo apt-get install linux-headers-generic autotools-dev build-essential cmake cpp libboost-signals1.46.1 libboost-signals1.46-dev libboost-thread1.46.1 libboost-thread1.46-dev libcv2.3 libcv-dev libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-dev libopencv-features2d-dev libopencv-calib3d-dev libgnomecanvas2-0 libgnomecanvas2-dev libgsl0-dev libgtk2.0-dev libjpeg62-dev libtool libxmu-dev swig python2.7-dev libcv-dev libcvaux-dev libhighgui-dev
OR
If you’re running Ubuntu 11.10 64bit install these dependencies instead:
sudo apt-get install linux-headers-generic autotools-dev build-essential cmake cpp libboost-signals1.46.1 libboost-signals1.46-dev libboost-thread1.46.1 libboost-thread1.46-dev libcv2.1 libcv-dev libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-dev libgnomecanvas2-0 libgnomecanvas2-dev libgsl0-dev libgtk2.0-dev libjpeg62-dev libtool libxmu-dev swig python2.7-dev libcv-dev libcvaux-dev libhighgui-dev
OK, now to download Player and Stage -
mkdir ~/pas
cd ~/pas
wget http://sourceforge.net/projects/playerstage/files/Player/3.0.2/player-3.0.2.tar.gz
wget http://sourceforge.net/projects/playerstage/files/Stage/3.2.2/Stage-3.2.2-Source.tar.gz
Now to extract and install Player -
tar -xvf player-3.0.2.tar.gz
cd ~/pas/player-3.0.2
mkdir ~/pas/player-3.0.2/build
cd ~/pas/player-3.0.2/build
cmake ../
make
sudo make install
cd ~
sudo updatedb
OK, now for Stage -
Install these dependencies (12.04 and 11.10 64bit):
sudo apt-get install freeglut3 freeglut3-dev libfltk1.1 libfltk1.1-dev libltdl7 libltdl-dev libpng12-dev libpng12-0
Now to extract Stage:
cd ~/pas
tar -xvf Stage-3.2.2-Source.tar.gz
Now you need to edit 3 lines in the CMakeLists.txt file -
gedit ~/pas/Stage-3.2.2-Source/build/CMakeLists.txt
Find the lines that read:-
SET (CMAKE_CXX_FLAGS_RELEASE " -O3 -DNDEBUG ${WALL} " CACHE INTERNAL "C Flags for release" FORCE) SET (CMAKE_CXX_FLAGS_DEBUG " -ggdb ${WALL} " CACHE INTERNAL "C Flags for debug" FORCE) SET (CMAKE_CXX_FLAGS_PROFILE " -O3 -ggdb -pg ${WALL} " CACHE INTERNAL "C Flags for profile" FORCE)
and change them to:-
SET (CMAKE_CXX_FLAGS_RELEASE " -O3 -DNDEBUG -Wl,--no-as-needed " CACHE INTERNAL "C Flags for release" FORCE) SET (CMAKE_CXX_FLAGS_DEBUG " -ggdb -Wl,--no-as-needed " CACHE INTERNAL "C Flags for debug" FORCE) SET (CMAKE_CXX_FLAGS_PROFILE " -O3 -ggdb -pg -Wl,--no-as-needed " CACHE INTERNAL "C Flags for profile" FORCE)
Back in the terminal run:
mkdir ~/pas/Stage-3.2.2-Source/build
cd ~/pas/Stage-3.2.2-Source/build
cmake ../
make
sudo make install
And now to test …
cd ~/pas/Stage-3.2.2-Source/worlds
player simple.cfg
I’m gona have a bash on this tomorrow/today.
Thanks alot for the help! I didn’t expect this much (so quick!) and I will inform you if I succeed or not!
Thanks again,
Mally.
Sadly, more errors arise.
So close.
Odd, it worked for me in Ubuntu 11.10 64bit
Currently I can’t get a 12.04 64bit VM to work, but I’ll try it in a 12.04 32bit VM install and see what happens.
Then if necessary I’ll get around to updating my 11.10 64bit PC to 12.04 64bit … but that may take a little longer :wink:
Oki doke.
This is such a pain. sigh
