Need more help with Epson-355 printer
I am back again with this printer.
I carried out your original instructions and the printer prints ok.
But the scanner doesn’t work, when I try to scan from the printer/scanner to the computer it produces an error :-
Communication error. Check the connection.
I have been ignoring this for a while now and have just the the Windows computer and the Brother printer to do my scanning but it is beginning to irk me that I purchased this NEW printer/scanner and I have failed to get it working to my satisfaction.
I believe the manufacturer spends more on research finding ways to stop the use alien printing ink cartridges than they do on making a useful printer that can be used/set up by idiots like me.
Rant ober, hope you can help.
Don W
Can you point me to the instructions you followed so I can see what you did ?
Re: HELP needed to install Epson XP-355 wireless printer AGAIN
« Reply #11 on: October 16, 2018, 01:07:49 am »
Go to
Menu > Settings > Printers
right-click on any listed printers and click “Delete”
When you have NO printers left, go here
http://download.ebz.epson.net/dsc/search/01/search/?OSC=LX
and search for
XP-355
Linux
you now need to download the files
epson-inkjet-printer-escpr_1.6.31-1lsb3.2_amd64.deb
epson-printer-utility_1.0.2-1lsb3.2_amd64.deb
and double-click them to install them.
Once installed, go back to
and click “Add”
Step through the installation … when it prompts you to choose a driver, select
Epson > XP-352 355 > Epson XP-352 355 Series - epson-inkjet-printer-escpr 1.6.31-1lsb3.2 (Seiko Epson Corporation LSB 3.2) [en] (recommended)
Mark, this was the post I followed although the versions 1.6 are now 1.7. Thanks
Are we still talking about Peppermint 9 64bit ?
If so run:
mkdir ~/ImageScan
cd ~/ImageScan
wget https://download2.ebz.epson.net/imagescanv3/ubuntu/lts1/deb/x64/imagescan-bundle-ubuntu-18.04-3.57.0.x64.deb.tar.gz
tar xvf imagescan-bundle-ubuntu-18.04-3.57.0.x64.deb.tar.gz
cd ~/ImageScan/imagescan-bundle-ubuntu-18.04-3.57.0.x64.deb
sudo ./install.sh
then look for “Image Scan” in the main menu … probably at:-
Menu > Graphics > Image Scan
If Image Scan doesn’t work, how is your printer/scanner attached to the PC ?
Thanks Mark,
I carried out your suggestions and the scan facility is now working. I have the computer connected by the USB cable and all is now well.
Thanks AGAIN for your help.
take care
Don W
You’re most welcome Don :slight_smile:
