Need sound and parameters. Module or builtin? Why?
alsaconf :
No supported PnP or PCI card found
Probe legacy - no legacy.
make menuconfig
Device Drivers > Sound card support * >
Preclaim OSS device numbers *
<*>   Advanced Linux Sound Architecture  --->
<*>   OSS Mixer API                                                         │ │
  │ │      <*>   OSS PCM (digital audio) API                                           │ │
  │ │      [*]     OSS PCM (digital audio) API - Include plugin system
 [*]   PCI sound devices  --->
<*>   (Creative) Ensoniq AudioPCI 1371/1373
What to set inside
< >   Intel HD Audio  --->
│ │      (64)  Pre-allocated buffer size for HD-audio driver (NEW)                   │ │
  │ │      [ ]   Build hwdep interface for HD-audio driver (NEW)                       │ │
  │ │      [ ]   Support digital beep via input layer (NEW)                            │ │
  │ │      [ ]   Support jack plugging notification via input layer (NEW)              │ │
  │ │      [ ]   Support initialization patch loading for HD-audio (NEW)               │ │
  │ │      [*]   Build Realtek HD-audio codec support (NEW)                            │ │
  │ │      [*]     Build static quirks for Realtek codecs (NEW)                        │ │
  │ │      [*]   Build Analog Device HD-audio codec support (NEW)                      │ │
  │ │      [*]   Build IDT/Sigmatel HD-audio codec support (NEW)                       │ │
  │ │      [*]   Build VIA HD-audio codec support (NEW)                                │ │
  │ │      [*]   Build HDMI/DisplayPort HD-audio codec support (NEW)                   │ │
  │ │      [*]   Build Cirrus Logic codec support (NEW)                                │ │
  │ │      [*]   Build Conexant HD-audio codec support (NEW)                           │ │
  │ │      [*]   Build Creative CA0110-IBG codec support (NEW)                         │ │
  │ │      [*]   Build Creative CA0132 codec support (NEW)                             │ │
  │ │      [*]   Build C-Media HD-audio codec support (NEW)                            │ │
  │ │      [*]   Build Silicon Labs 3054 HD-modem codec support (NEW)                  │ │
  │ │      [*]   Enable generic HD-audio codec parser (NEW)
And where is PnP - it is not supported by emerged alsa
localhost xi # emerge --info | wgetpaste
Your paste can be seen here: http://bpaste.net/show/54833/
localhost xi # lspci -v | grep -i audio | wgetpaste
Your paste can be seen here: http://bpaste.net/show/54835/
localhost xi # cat /usr/src/linux/.config | wgetpaste
Your paste can be seen here: http://bpaste.net/show/54836/
